AutoCAD 2024 开发者帮助
Layouts 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 999| 评论: 0|原作者: admin|来自: AutoCAD
获取文档的 Layouts 集合。
object.Layouts
类型:数据库、文档
此属性应用于的对象。
只读:是的
类型: 布局
文档的 Layouts 集合。
Sub Example_Layouts()
    ' This example will access the Layouts collection for the current drawing
    ' and list basic information about the Layouts in the drawing.
    Dim Layouts As AcadLayouts, Layout As ACADLayout
    Dim msg As String
    ' Get layouts collection from document object
    Set Layouts = ThisDrawing.Layouts
    msg = vbCrLf    ' Start with a space
    ' Get the names of every layout in this drawing
    For Each Layout In Layouts
        msg = msg & Layout.name & vbCrLf
    Next
    ' Display a list of available layouts
    MsgBox "There are " & Layouts.count & " layouts in " & _
           ThisDrawing.WindowTitle & ":" & msg
(defun c:Example_Layouts()
    ;; This example will access the Layouts collection for the current drawing
    ;; and list basic information about the Layouts in the drawing.
    ;; Get layouts collection from document object
    (setq Layouts (vla-get-Layouts doc))
    (setq msg "")   ;; Start with a space
    ;; Get the names of every layout in this drawing
    (vlax-for Layout Layouts
        (setq msg (strcat msg (vla-get-Name Layout) "\n"))
    ;; Display a list of available layouts
    (alert (strcat "There are " (itoa (vla-get-Count Layouts)) " layouts in "
                   (vla-get-WindowTitle doc) ":\n" msg))
GMT+8, 2026-10-26 10:53
