AutoCAD 2024 开发者帮助
ImageFile 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 759| 评论: 0|原作者: admin|来自: AutoCAD
指定光栅图像文件的完整路径和文件名。
object.ImageFile
类型:GeomapImage、RasterImage、Wipeout
此属性应用于的对象。
只读:不
类型:字符串
光栅图像文件的完整路径和文件名。
此属性与该属性类似,不同之处在于此属性包含路径信息,而该属性不包含路径信息。NameName
可以使用此属性将新的栅格图像加载到现有栅格对象中。
Sub Example_ImageFile()
    ' This example inserts a raster image and then finds the
    ' ImageFile for the image.
    ' This example uses the "2d Projected Polylines.jpg" found in the Sample
    ' directory. If you do not have the image, or if it is located
    ' in a different directory, insert a valid path and name for the
    ' imageName variable below.
    Dim scalefactor As Double
    Dim rotAngleInDegree As Double, rotAngle As Double
    Dim imageName As String
    Dim raster As AcadRasterImage
    imageName = "C:\AutoCAD\sample\2d Projected Polylines.jpg"
    insertionPoint(0) = 2#: insertionPoint(1) = 2#: insertionPoint(2) = 0#
    scalefactor = 1#
    rotAngleInDegree = 0#
    rotAngle = rotAngleInDegree * 3.141592 / 180#
    On Error Resume Next
    ' Creates a raster image in model space
    Set raster = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotAngle)
    If Err.Description = "File error" Then
        MsgBox imageName & " could not be found."
        Exit Sub
    End If
    ' Find the current ImageFile
    ThisDrawing.Regen True
    MsgBox "The ImageFile is currently set to: " & raster.ImageFile, vbInformation
(defun c:Example_ImageFile()
    ;; This example inserts a raster image and then finds the
    ;; ImageFile for the image.
    ;; This example uses the "2d Projected Polylines.jpg" found in the Sample
    ;; directory. If you do not have the image, or if it is located
    ;; in a different directory, insert a valid path and name for the
    ;; imageName variable below.
    (setq insertionPoint (vlax-3d-point 5 5 0)
          imageName ".\\Sample\\VBA\\2d Projected Polylines.jpg"
          scalefactor 1
          rotAngle (/ (* 0 3.141592) 180))
    ;; Creates a raster image in model space
    (if (/= (findfile imageName) nil)
        (progn
            (setq raster (vla-AddRaster modelSpace (findfile imageName) insertionPoint scalefactor rotAngle))
            (vla-ZoomExtents acadObj)
        (alert (strcat imageName " could not be found."))
    ;; Find the current ImageFile
    (vla-Regen doc :vlax-true)
    (alert (strcat "The ImageFile is currently set to: " (vla-get-ImageFile raster)))
GMT+8, 2026-11-1 08:08
