AutoCAD 2024 开发者帮助
HatchObjectType 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 997| 评论: 0|原作者: admin|来自: AutoCAD
指定填充线的类型,经典或渐变。
object.HatchObjectType
类型:舱口
此属性应用于的对象。
只读:不
类型:枚举AcHatchObjectType
  • acHatchObject
  • acGradientObject
此属性的默认值为 0, ,这将创建一个经典的填充线。acHatchObject
如果此属性的值为 1, ,则通过创建填充线的方法创建渐变。如果创建了渐变,则应且应包含梯度图案名称 LINEAR、CYLINDER、INVCYLINDER、SPHERICAL、HEMISPHERICAL、CURVED、INVSPHERICAL、INVHEMISPHERICAL 或 INVCURVED。acGradientObjectAddHatchPatternTypeAcGradientPatternTypePatternName
Sub Example_HatchObjectType()
    ' This example changes the value of the HatchObjectType property.
    ' The example requires that the active drawing contain an existing hatch.
    Dim ent As AcadHatch
    Dim util As AcadUtility
    Set util = ThisDrawing.Utility
    Dim pt As Variant
    Call util.GetEntity(ent, pt, "Select hatch :")
    With ent
        MsgBox "Initial value of HatchObjectType = " & .HatchObjectType
        .HatchObjectType = acGradientObject
        .GradientAngle = 3.1415 / 4
        .GradientCentered = False
        .GradientName = "SPHERICAL"
        Dim col1 As AcadAcCmColor, col2 As AcadAcCmColor
        Set col1 = .GradientColor1
        Set col2 = .GradientColor2
        col1.SetRGB 255, 0, 0
        col2.SetRGB 0, 255, 0
        .GradientColor1 = col1
        .GradientColor2 = col2
        MsgBox "New value of HatchObjectType = " & .HatchObjectType
    End With
(defun c:Example_HatchObjectType()
    ;; This example changes the value of the HatchObjectType property.
    ;; The example requires that the active drawing contain an existing hatch.
          doc (vla-get-ActiveDocument acadObj)
          util (vla-get-Utility doc))
    (vla-GetEntity util 'ent 'pt "Select hatch :")
    (alert (strcat "Initial value of HatchObjectType = " (itoa (vla-get-HatchObjectType ent))))
    (vla-put-HatchObjectType ent acGradientObject)
    (vla-put-GradientAngle ent (/ 3.1415 4))
    (vla-put-GradientCentered ent :vlax-false)
    (vla-put-GradientName ent "SPHERICAL")
    (setq col1 (vla-get-GradientColor1 ent)
          col2 (vla-get-GradientColor1 ent))
    (vla-SetRGB col1 255 0 0)
    (vla-SetRGB col2 0 255 0)
    (vla-put-GradientColor1 ent col1)
    (vla-put-GradientColor2 ent col2)
    (alert (strcat "New value of HatchObjectType = " (itoa (vla-get-HatchObjectType ent))))
GMT+8, 2026-10-22 20:34
