AutoCAD 2024 开发者帮助
Groups 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 1003| 评论: 0|原作者: admin|来自: AutoCAD
Groups 属性 (ActiveX)
获取文档的 Groups 集合。
object.Groups
类型:数据库、文档
此属性应用于的对象。
只读:是的
类型: 组
文档的 Groups 集合。
Sub Example_Groups()
    ' This example finds the current Groups collection and
    ' adds a new group to that collection.
    Dim groupColl As AcadGroups
    Set groupColl = ThisDrawing.Groups
    ' Create a dimension style named "TEST" in current drawing
    Dim testGroup As AcadGroup
    Set testGroup = groupColl.Add("TEST")
    MsgBox "A new group called " & testGroup.name & " has been added to the Groups collection.", vbInformation, "Groups Example"
(defun c:Example_Groups()
    ;; This example finds the current Groups collection and
    ;; adds a new group to that collection.
    (setq groupColl (vla-get-Groups doc))
    ;; Create a dimension style named "TEST" in current drawing
    (setq testGroup (vla-Add groupColl "TEST"))
    (alert (strcat "A new group called " (vla-get-Name testGroup) " has been added to the Groups collection."))
GMT+8, 2026-10-22 12:48
