AutoCAD 2024 开发者帮助
GripColorSelected 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 811| 评论: 0|原作者: admin|来自: AutoCAD
指定所选夹点的颜色。
object.GripColorSelected
类型:首选项选择
此属性应用于的对象。
只读:不
类型:枚举acColor
控制选定的夹具(绘制为填充框)。有效范围为 1 到 255,或此处列出的常量之一:
  • acRed
  • acYellow
  • acGreen
  • acCyan
  • acBlue
  • acMagenta
  • acWhite
此属性的初始值为 12。
注意:此属性的值存储在 GRIPHOT 系统变量中。
Sub Example_GripColorSelected()
    ' This example reads and modifies the preference value that controls
    ' the color of selected grips.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesSelection
    ' Get the selection preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Selection
    originalValue = ACADPref.GripColorSelected
    MsgBox "The GripColorSelected preference is set to: " & originalValue
    ' Modify the GripColorSelected preference by setting it to green
    ACADPref.GripColorSelected = acGreen
    newValue = ACADPref.GripColorSelected
    MsgBox "The GripColorSelected preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.GripColorSelected = originalValue
    MsgBox "The GripColorSelected preference was reset back to: " & originalValue
(defun c:Example_GripColorSelected()
    ;; This example reads and modifies the preference value that controls
    ;; the color of selected grips.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    ;; Get the selection preferences object
    (setq ACADPref (vla-get-Selection (vla-get-preferences acadObj)))
    (setq originalValue (vla-get-GripColorSelected ACADPref))
    (alert (strcat "The GripColorSelected preference is set to: " (itoa originalValue)))
    ;; Modify the GripColorSelected preference by setting it to green
    (vla-put-GripColorSelected ACADPref acGreen)
    (setq newValue (vla-get-GripColorSelected ACADPref))
    (alert (strcat "The GripColorSelected preference has been set to: " (itoa newValue)))
    ;;         this preference in effect
    (vla-put-GripColorSelected ACADPref originalValue)
    (alert (strcat "The GripColorSelected preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-23 08:46
