AutoCAD 2024 开发者帮助
Freeze 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 752| 评论: 0|原作者: admin|来自: AutoCAD
Freeze 属性 (ActiveX)
指定图层的冻结状态。
object.Freeze
类型:图层
此属性应用于的对象。
只读:不
类型:布尔
  • True:冻结图层。
  • False:解冻图层。
冻结层使它们不可见,并将它们排除在再生和绘图之外。解冻图层可实现这些功能。关闭或冻结图层上的 AutoCAD 曲面和圆是不可见的,但在使用 HIDE、SHADEMODE 或 RENDER 命令时,它们仍会隐藏对象。
不能冻结活动图层,也不能使冻结图层处于活动状态。
此属性与属性不同,因为在再生期间不会生成冻结图层。LayerOn
Sub Example_Freeze()
    ' This example creates a new layer called "Freeze".
    ' It then displays the status of the Freeze property
    ' for the new layer, toggles the status of the
    ' Freeze property, and again displays its status.
    ' After running this example, you can check the layer
    ' control on the Object Properties tool bar. It will
    ' show the new layer and the latest Freeze status.
    Dim layerObj As AcadLayer
    ' Create the new layer
    Set layerObj = ThisDrawing.Layers.Add("Freeze")
    ' Display the Freeze status of the new layer
    GoSub DISPLAYSTATUS
    ' Toggle the status of the Freeze property for the layer
    layerObj.Freeze = Not (layerObj.Freeze)
    GoSub DISPLAYSTATUS
    Exit Sub
DISPLAYSTATUS:
    If layerObj.Freeze Then
        MsgBox "Layer " & layerObj.name & " is frozen.", , "Freeze Example"
    Else
        MsgBox "Layer " & layerObj.name & " is thawed.", , "Freeze Example"
    End If
    Return
(defun c:Example_Freeze()
    ;; This example creates a new layer called "Freeze".
    ;; It then displays the status of the Freeze property
    ;; for the new layer, toggles the status of the
    ;; Freeze property, and again displays its status.
    ;; After running this example, you can check the layer
    ;; control on the Object Properties tool bar. It will
    ;; show the new layer and the latest Freeze status.
    ;; Create the new layer
    (setq layerObj (vla-Add (vla-get-Layers doc) "Freeze"))
    ;; Display the Freeze status of the new layer
    (if (= (vla-get-Freeze layerObj) :vlax-true)
        (alert (strcat "Layer " (vla-get-Name layerObj) " is frozen."))
        (alert (strcat "Layer " (vla-get-Name layerObj) " is thawed."))
    ;; Toggle the status of the Freeze property for the layer
    (vla-put-Freeze layerObj (if (= (vla-get-Freeze layerObj) :vlax-true) :vlax-false :vlax-true))
GMT+8, 2026-10-22 11:11
