AutoCAD 2024 开发者帮助
FractionFormat 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 877| 评论: 0|原作者: admin|来自: AutoCAD
指定尺寸和公差中分数值的格式。
object.FractionFormat
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:枚举acDimFractionType
  • acHorizontal
  • acDiagonal
  • acNotStacked
当属性设置为 或 时,将使用此属性。UnitsFormatacDimLArchitecturalacDimLFractional
注意:此属性将覆盖给定尺寸的 DIMFRAC 系统变量的值。
Sub Example_FractionFormat()
    ' uses FractionFormat to cycle through some fractional formats
    ' for the dimension.
    ' * Note the appearance of the "1/2" component of the dimension
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point1(0) = 0: point1(1) = 5: point1(2) = 0
    point2(0) = 5.5: point2(1) = 5: point2(2) = 0
    ' Switch to a mode that works with the FractionFormat property
    dimObj.UnitsFormat = acDimLArchitectural
    ' Cycle through some common fractional formats
    dimObj.FractionFormat = acDiagonal      ' Change format to Diagonal
    MsgBox "The dimension format is now set to diagonal"
    dimObj.FractionFormat = acHorizontal    ' Change format to Horizontal
    MsgBox "The dimension format is now set to horizontal"
    dimObj.FractionFormat = acNotStacked    ' Change format to NotStacked
    MsgBox "The dimension format is now unstacked"
(defun c:Example_FractionFormat()
   ;; uses FractionFormat to cycle through some fractional formats
   ;; for the dimension.
   ;; * Note the appearance of the "1/2" component of the dimension
    ;; Define the dimension
    (setq point1 (vlax-3d-point 0 5 0)
          point2 (vlax-3d-point 5.5 5 0)
    (vla-ZoomAll acadObj)
    ;; Switch to a mode that works with the FractionFormat property
    (vla-put-UnitsFormat dimObj acDimLArchitectural)
    ;; Cycle through some common fractional formats
    (vla-put-FractionFormat dimObj acDiagonal)      ;; Change format to Diagonal
    (alert "The dimension format is now set to diagonal")
    (vla-put-FractionFormat dimObj acHorizontal)    ;; Change format to Horizontal
    (alert "The dimension format is now set to horizontal")
    (vla-put-FractionFormat dimObj acNotStacked)    ;; Change format to NotStacked
    (alert "The dimension format is now unstacked")
GMT+8, 2026-10-30 02:55
