AutoCAD 2024 开发者帮助
ExtensionLineOffset 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 841| 评论: 0|原作者: admin|来自: AutoCAD
指定延伸线与原点的偏移距离。
object.ExtensionLineOffset
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、DimOrdinate、DimRotated
此属性应用于的对象。
只读:不
类型:双
一个正实数,指定将延伸线偏移到原点之外的距离。
此属性的初始值为 0.0625。
注意:此属性将覆盖给定维度的 DIMEXO 系统变量的值。
Sub Example_ExtensionLineOffset()
    ' This example creates a Dim3PointAngular object in model space
    ' and changes the offset of the extension lines using the
    ' ExtensionLineOffset property
    Dim DimPointAngularObj As AcadDim3PointAngular
    Dim AngleVertex(0 To 2) As Double
    Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
    Dim TextPoint(0 To 2) As Double
    ' Define the new Dim3PointAngular object
    AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
    FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
    SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
    TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
    ' Create the new Dim3PointAngular object in model space
    Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
    ' Read and display current offset of the extension lines from the control points
    MsgBox "The extension lines are currently offset " & DimPointAngularObj.ExtensionLineOffset & " units"
    ' Change the extension lines offset distance from the control points
    DimPointAngularObj.ExtensionLineOffset = 1.5
    MsgBox "The extension lines are now offset " & DimPointAngularObj.ExtensionLineOffset & " units"
(defun c:Example_ExtensionLineOffset()
    ;; This example creates a Dim3PointAngular object in model space
    ;; and changes the offset of the extension lines using the
    ;; ExtensionLineOffset property
    ;; Define the new Dim3PointAngular object
    (setq AngleVertex (vlax-3d-point 0 0 0)
          FirstPoint (vlax-3d-point 2 2 0)
          SecondPoint (vlax-3d-point 1 4 0)
          TextPoint (vlax-3d-point 6 6 0))
    ;; Create the new Dim3PointAngular object in model space
    (setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
    (vla-ZoomAll acadObj)
    ;; Read and display current offset of the extension lines from the control points
    (alert (strcat "The extension lines are currently offset " (rtos (vla-get-ExtensionLineOffset DimPointAngularObj) 2) " units"))
    ;; Change the extension lines offset distance from the control points
    (vla-put-ExtensionLineOffset DimPointAngularObj 1.5)
    (alert (strcat "The extension lines are now offset " (rtos (vla-get-ExtensionLineOffset DimPointAngularObj) 2) " units"))
GMT+8, 2026-10-22 13:01
