AutoCAD 2024 开发者帮助
ExtensionLineExtend 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 1114| 评论: 0|原作者: admin|来自: AutoCAD
指定延伸线延伸到尺寸线之外的距离。
object.ExtensionLineExtend
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimRotated
此属性应用于的对象。
只读:不
类型:双
一个正实数,指定将延伸线延伸到尺寸线之外的距离。
此属性的初始值为 0.1800。
注意:此属性将覆盖给定维度的 DIMEXE 系统变量的值。
Sub Example_ExtensionLineExtend()
    ' This example creates a Dim3PointAngular object in model space
    ' and changes the length of the extension line to extend 1.5 units past
    ' the dimension using the ExtensionLineExtend property
    Dim DimPointAngularObj As AcadDim3PointAngular
    Dim AngleVertex(0 To 2) As Double
    Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
    Dim TextPoint(0 To 2) As Double
    ' Define the new Dim3PointAngular object
    AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
    FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
    SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
    TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
    ' Create the new Dim3PointAngular object in model space
    Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
    ' Read and display current extension line extend length
    MsgBox "The extension line currently extends " & DimPointAngularObj.ExtensionLineExtend & " units past the dimension"
    ' Change the extension line extend length to extend 1.5
    ' units past the dimension
    DimPointAngularObj.ExtensionLineExtend = 1.5
    MsgBox "The extension line now extends " & DimPointAngularObj.ExtensionLineExtend & " units past the dimension"
(defun c:Example_ExtensionLineExtend()
    ;; This example creates a Dim3PointAngular object in model space
    ;; and changes the length of the extension line to extend 1.5 units past
    ;; the dimension using the ExtensionLineExtend property
    ;; Define the new Dim3PointAngular object
    (setq AngleVertex (vlax-3d-point 0 0 0)
          FirstPoint (vlax-3d-point 2 2 0)
          SecondPoint (vlax-3d-point 1 4 0)
          TextPoint (vlax-3d-point 6 6 0))
    ;; Create the new Dim3PointAngular object in model space
    (setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
    (vla-ZoomAll acadObj)
    ;; Read and display current extension line extend length
    (alert (strcat "The extension line currently extends " (rtos (vla-get-ExtensionLineExtend DimPointAngularObj) 2) " units past the dimension"))
    ;; Change the extension line extend length to extend 1.5
    ;; units past the dimension
    (vla-put-ExtensionLineExtend DimPointAngularObj 1.5)
    (alert (strcat "The extension line now extends " (rtos (vla-get-ExtensionLineExtend DimPointAngularObj) 2) " units past the dimension"))
GMT+8, 2026-10-23 00:42
