AutoCAD 2024 开发者帮助
EntityColor 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 1051| 评论: 0|原作者: admin|来自: AutoCAD
指定真颜色的颜色值。
object.EntityColor
类型:AcCmColor
此属性应用于的对象。
只读:不
类型:长
真彩色的颜色值。
此属性指定颜色的 32 位部分。AcCmEntityColor
Sub Example_EntityColor()
    Dim line As AcadLine
    Set line = CreateLine
    Dim color As AcadAcCmColor
    Set color = line.TrueColor
    Dim y As Long
    y = MakeLong(MakeWord(194, 122), MakeWord(133, 144))
    color.EntityColor = y
    line.TrueColor = color
    Dim retcolor As AcadAcCmColor
    Set retcolor = line.TrueColor
    Dim x As Long
    x = retcolor.EntityColor
    Dim BreakLong(3) As Byte
    BreakLong(0) = x And &HFF&
    BreakLong(1) = (x And &HFF00&) \ &H100&
    BreakLong(2) = (x And &HFF0000) \ &H10000
    BreakLong(3) = (x And &H7F000000) \ &H1000000
    If x < 0 Then BreakLong(3) = BreakLong(3) Or &H80
    MsgBox "ColorMethod = " & BreakLong(3) & vbCrLf & _
           "Red = " & BreakLong(2) & vbCrLf & _
           "Green = " & BreakLong(1) & vbCrLf & _
           "Blue = " & BreakLong(0)
Private Function CreateLine() As AcadLine
    Dim lineObj As AcadLine
    startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0#
    endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0#
    Set CreateLine = lineObj
    ZoomAll
End Function
Private Function MakeLong(WordHi As Variant, WordLo As Integer) As Long
   ' High word is coerced to a variant on the call, to allow
   ' it to overflow the limits of multiplication, which shifts
   ' it left.
   MakeLong = (WordHi * &H10000) + (WordLo And &HFFFF&)
End Function
Private Function MakeWord(ByteHi As Byte, ByteLo As Byte) As Integer
   ' If the high byte would push the final result out of the
   ' signed integer range, it must be slid back.
   If ByteHi > &H7F Then
      MakeWord = ((ByteHi * &H100&) + ByteLo) - &H10000
   Else
      MakeWord = (ByteHi * &H100&) + ByteLo
   End If
End Function
(defun c:Example_EntityColor()
          doc (vla-get-ActiveDocument acadObj))
    (setq modelSpace (vla-get-ModelSpace doc)
          line (CreateLine)
          color (vla-get-TrueColor line))
    (setq y (MakeLong (MakeWord 194 122) (MakeWord 133 144)))
    (vla-put-EntityColor color y)
    (vla-put-TrueColor line color)
    (setq retcolor (vla-get-TrueColor line))
    (setq x (vla-get-EntityColor retcolor))
    (setq BreakLong (vlax-make-safearray vlax-vbDouble '(0 . 3)))
    (vlax-safearray-put-element BreakLong 0 (logand x 255))
    (vlax-safearray-put-element BreakLong 1 (/ (logand x 65280) 256))
    (vlax-safearray-put-element BreakLong 2 (/ (logand x 16711680) 65536))
    (vlax-safearray-put-element BreakLong 3 (/ (logand x 2130706432) 16777216))
    (if (< x 0)
        (vlax-safearray-put-element BreakLong 3 (logior (fix (vlax-safearray-get-element BreakLong 3)) 128))
    (alert (strcat "ColorMethod = " (itoa (fix (vlax-safearray-get-element BreakLong 3))) "\n"
                   "Red = " (itoa (fix (vlax-safearray-get-element BreakLong 2))) "\n"
                   "Green = " (itoa (fix (vlax-safearray-get-element BreakLong 1))) "\n"
                   "Blue = " (itoa (fix (vlax-safearray-get-element BreakLong 0)))))
(defun CreateLine()
    (setq startPoint (vlax-3d-point 1 1 0)
          endPoint (vlax-3d-point 5 5 0))
          lineObj (vla-AddLine modelSpace startPoint endPoint))
    (vla-ZoomAll acadObj)
    lineObj
(defun MakeLong (WordHi WordLo)
   ;; High word is coerced to a variant on the call, to allow
   ;; it to overflow the limits of multiplication, which shifts
   ;; it left.
   (+ (* WordHi 65536) (logand WordLo 65535))
(defun MakeWord(ByteHi ByteLo)
   ;; If the high byte would push the final result out of the
   ;; signed integer range, it must be slid back.
   (if (> ByteHi 127)
      (- (+ (* ByteHi 256) ByteLo) 65536)
GMT+8, 2026-11-2 16:02
