AutoCAD 2024 开发者帮助
EnableStartupDialog 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 762| 评论: 0|原作者: admin|来自: AutoCAD
指定在启动 AutoCAD 或创建新图形时是否显示启动对话框。
object.EnableStartupDialog
类型:PreferencesSystem
此属性应用于的对象。
只读:
类型:布尔
  • True:显示启动对话框。
  • False:不显示启动对话框。
此属性的初始值为 。False
当 EnableStartupDialog 为 时,可以显示传统的启动对话框。True
Sub Example_EnableStartupDialog()
    ' EnableStartupDialog. It then changes the value, and finally
    Dim currEnableStartupDialog As Boolean
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current EnableStartupDialog value
    currEnableStartupDialog = preferences.System.EnableStartupDialog
    MsgBox "The current value for EnableStartupDialog is " & preferences.System.EnableStartupDialog, vbInformation, "EnableStartupDialog Example"
    ' Change the value for EnableStartupDialog
    preferences.System.EnableStartupDialog = Not (currEnableStartupDialog)
    MsgBox "The new value for EnableStartupDialog is " & preferences.System.EnableStartupDialog, vbInformation, "EnableStartupDialog Example"
    ' Reset EnableStartupDialog to its original value
    preferences.System.EnableStartupDialog = currEnableStartupDialog
    MsgBox "The EnableStartupDialog value is reset to " & preferences.System.EnableStartupDialog, vbInformation, "EnableStartupDialog Example"
(defun c:Example_EnableStartupDialog()
    ;; EnableStartupDialog. It then changes the value, and finally
    ;; Get the system preferences object
    (setq ACADPref (vla-get-System preferences))
    ;; Retrieve the current EnableStartupDialog value
    (setq currEnableStartupDialog (vla-get-EnableStartupDialog ACADPref))
    (alert (strcat "The current value for EnableStartupDialog is " (if (= currEnableStartupDialog :vlax-true) "True" "False")))
    ;; Change the value for EnableStartupDialog
    (vla-put-EnableStartupDialog ACADPref (if (= currEnableStartupDialog :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-EnableStartupDialog ACADPref))
    (alert (strcat "The new value for EnableStartupDialog is " (if (= newValue :vlax-true) "True" "False")))
    ;; Reset EnableStartupDialog to its original value
    (vla-put-EnableStartupDialog ACADPref currEnableStartupDialog)
    (alert (strcat "The EnableStartupDialog value is reset to " (if (= currEnableStartupDialog :vlax-true) "True" "False")))
GMT+8, 2026-9-6 18:49
