AutoCAD 2024 开发者帮助
DockedVisibleLines 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 874| 评论: 0|原作者: admin|来自: AutoCAD
指定要在命令窗口中显示的文本行数。(已过时)
object.DockedVisibleLines
类型:首选项显示
此属性应用于的对象。
只读:不
类型:整数
一个正整数,表示要在命令窗口中显示的文本行数。
Sub Example_DockedVisibleLines()
    ' DockedVisibleLines. It then changes the value, and finally
    Dim currDockedVisibleLines As Integer
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current DockedVisibleLines value
    currDockedVisibleLines = preferences.Display.DockedVisibleLines
    MsgBox "The current value for DockedVisibleLines is " & preferences.DISPLAY.DockedVisibleLines, vbInformation, "DockedVisibleLines Example"
    ' Change the value for DockedVisibleLines
    preferences.Display.DockedVisibleLines = 15
    MsgBox "The new value for DockedVisibleLines is " & preferences.DISPLAY.DockedVisibleLines, vbInformation, "DockedVisibleLines Example"
    ' Reset DockedVisibleLines to its original value
    preferences.Display.DockedVisibleLines = currDockedVisibleLines
    MsgBox "The DockedVisibleLines value is reset to " & preferences.Display.DockedVisibleLines, vbInformation, "DockedVisibleLines Example"
(defun c:Example_DockedVisibleLines()
    ;; DockedVisibleLines. It then changes the value, and finally
    ;; Get the Display preferences object
    (setq ACADPref (vla-get-Display preferences))
    ;; Retrieve the current DockedVisibleLines value
    (setq currDockedVisibleLines (vla-get-DockedVisibleLines ACADPref))
    (alert (strcat "The current value for DockedVisibleLines is " (itoa currDockedVisibleLines)))
    ;; Change the value for DockedVisibleLines
    (setq newValue 15)
    (vla-put-DockedVisibleLines ACADPref newValue)
    (alert (strcat "The new value for DockedVisibleLines is " (itoa newValue)))
    ;; Reset DockedVisibleLines to its original value
    (vla-put-DockedVisibleLines ACADPref currDockedVisibleLines)
    (alert (strcat "The DockedVisibleLines value is reset to " (itoa currDockedVisibleLines)))
GMT+8, 2026-10-25 06:04
