AutoCAD 2024 开发者帮助
DimLineSuppress 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 800| 评论: 0|原作者: admin|来自: AutoCAD
指定禁止显示径向尺寸的尺寸线。
object.DimLineSuppress
类型:DimRadial、DimRadialLarge
此属性应用于的对象。
只读:不
类型:布尔
  • True:隐含尺寸线。
  • False:不要隐含尺寸线。
此属性的初始值为 。False
当此属性设置为 时,将禁止显示扩展线和文本之间的尺寸线和箭头。True
注意:此属性将重写 DIMSD2 系统变量的值。
Sub Example_DimLineSuppress()
   ' This example creates a Radial Dimension in model space and
   ' uses the DimLineSuppress property to toggle the display
   ' of the dimension lines
    Dim dimObj As AcadDimRadial
    Dim center(0 To 2) As Double
    Dim chordPoint(0 To 2) As Double
    Dim leaderLen As Integer
    ' Define the dimension
    center(0) = 0: center(1) = 0: center(2) = 0
    chordPoint(0) = 5: chordPoint(1) = 5: chordPoint(2) = 0
    leaderLen = 5
    ' Create the radial dimension in model space
    Set dimObj = ThisDrawing.ModelSpace.AddDimRadial(center, chordPoint, leaderLen)
    MsgBox "The radial dimension has been created.", vbInformation
    dimObj.DimLineSuppress = Not (dimObj.DimLineSuppress)
    MsgBox "The radial dimension appearance has been modified.", vbInformation
(defun c:Example_DimLineSuppress()
    ;; This example creates a Radial Dimension in model space and
    ;; uses the DimLineSuppress property to toggle the display
    ;; of the dimension lines
    ;; Define the dimension
    (setq center (vlax-3d-point 0 0 0)
          chordPoint (vlax-3d-point 5 5 0)
          leaderLen 5)
    ;; Create the radial dimension in model space
    (setq dimObj (vla-AddDimRadial modelSpace center chordPoint leaderLen))
    (vla-ZoomAll acadObj)
    (alert "The radial dimension has been created.")
    (vla-put-DimLineSuppress dimObj (if (= (vla-get-DimLineSuppress dimObj) :vlax-true) :vlax-false :vlax-true))
    (alert "The radial dimension appearance has been modified.")
GMT+8, 2026-10-23 13:49
