AutoCAD 2024 开发者帮助
Description 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 845| 评论: 0|原作者: admin|来自: AutoCAD
指定对象的说明。
object.Description
类型:DynamicBlockReferenceProperty、Layer、Linetype、Material、MLeaderStyle、TableStyle
此属性应用于的对象。
只读:
  • 否(对象除外):AutoCADDynamicBlockReferenceProperty
  • 否(对象和对象除外):AutoCAD LTDynamicBlockReferencePropertyMaterial
类型:字符串
分配给对象的描述。
动态块引用属性的描述由块作者设置,无法编辑。
线型描述最多可以包含 47 个字符。描述可以是注释,也可以是一系列下划线、点、破折号和空格,以显示线型模式的简单表示形式。
Sub Example_Description()
    ' This example returns the description of the active linetype.
    ' It then changes the description of the active linetype.
    Dim currDescription As String
    ' This example modifies the description of a linetype
    currDescription = ThisDrawing.ActiveLinetype.Description
    MsgBox "The description of the active LineType is: " & currDescription, vbInformation, "Description Example"
    ' Change the description of the active linetype
    ThisDrawing.ActiveLinetype.Description = "My favorite LineType"
    MsgBox "The new description of the active LineType is: " & ThisDrawing.ActiveLinetype.Description, vbInformation, "Description Example"
    ' Reset the description of the active linetype
    ThisDrawing.ActiveLinetype.Description = currDescription
    MsgBox "The description of the active LineType is reset to: " & ThisDrawing.ActiveLinetype.Description, vbInformation, "Description Example"
(defun c:Example_Description()
    ;; This example returns the description of the active linetype.
    ;; It then changes the description of the active linetype.
    ;; This example modifies the description of a linetype
    (setq currDescription (vla-get-Description (vla-get-ActiveLinetype doc)))
    (alert (strcat "The description of the active Linetype is: " currDescription))
    ;; Change the description of the active linetype
    (vla-put-Description (vla-get-ActiveLinetype doc) "My favorite LineType")
    (alert (strcat "The new description of the active Linetype is: " (vla-get-Description (vla-get-ActiveLinetype doc))))
    ;; Reset the description of the active linetype
    (vla-put-Description (vla-get-ActiveLinetype doc) currDescription)
    (alert (strcat "The description of the active Linetype is reset to: " currDescription))
GMT+8, 2026-11-1 07:08
