AutoCAD 2024 开发者帮助
DefaultOutputDevice 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 880| 评论: 0|原作者: admin|来自: AutoCAD
指定新布局和模型空间的默认输出设备。
object.DefaultOutputDevice
类型:首选项输出
此属性应用于的对象。
只读:不
类型:字符串
要使用的默认打印机的名称。
您可以指定计算机为其配置的任何打印机,以及绘图仪配置路径中的任何 PC3 文件。
如果系统上没有设备,则此属性将返回“None”。
Sub Example_DefaultOutputDevice()
    ' This example reads and modifies the preference value that controls
    ' the default output device for new layouts and model space.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesOutput
    ' Get the output preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Output
    originalValue = ACADPref.DefaultOutputDevice
    MsgBox "The DefaultOutputDevice preference is: " & originalValue
    ' Modify the DefaultOutputDevice preference
    ACADPref.DefaultOutputDevice = "DWG to PDF.pc3"
    newValue = ACADPref.DefaultOutputDevice
    MsgBox "The DefaultOutputDevice preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.DefaultOutputDevice = originalValue
    MsgBox "The DefaultOutputDevice preference was reset back to: " & originalValue
(defun c:Example_DefaultOutputDevice()
    ;; This example reads and modifies the preference value that controls
    ;; the default output device for new layouts and model space.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    ;; Get the output preferences object
    (setq ACADPref (vla-get-Output preferences))
    (setq originalValue (vla-get-DefaultOutputDevice ACADPref))
    (alert (strcat "The DefaultOutputDevice preference is: " originalValue))
    ;; Modify the DefaultOutputDevice preference
    (vla-put-DefaultOutputDevice ACADPref "DWG to PDF.pc3")
    (setq newValue (vla-get-DefaultOutputDevice ACADPref))
    (alert (strcat "The DefaultOutputDevice preference has been set to: " newValue))
    ;;         this preference in effect
    (vla-put-DefaultOutputDevice ACADPref originalValue)
    (alert (strcat "The DefaultOutputDevice preference was reset back to: " originalValue))
GMT+8, 2026-11-3 13:00
