AutoCAD 2024 开发者帮助
DecimalSeparator 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 988| 评论: 0|原作者: admin|来自: AutoCAD
指定要用作十进制尺寸和公差值中的小数分隔符的字符。
object.DecimalSeparator
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:字符串
在十进制值中用作分隔符的单个字符。
此属性的初始值为“.”。
任何字符都将被接受为此属性的有效值。
仅当该属性设置为 时,才会使用此属性。UnitsFormatacDimDecimal
注意:此属性将覆盖给定维度的 DIMDSEP 系统变量的值。
Sub Example_DecimalSeparator()
    ' This example creates a Dim3PointAngular object in model space
    ' and allows the user to change the decimal separator appearance
    ' using the DecimalSeparator property
    Dim DimPointAngularObj As AcadDim3PointAngular
    Dim AngleVertex(0 To 2) As Double
    Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
    Dim TextPoint(0 To 2) As Double
    Dim oldSeparator As String, newSeparator As String
    ' Define the new Dim3PointAngular object
    AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
    FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
    SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
    TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
    ' Create the new Dim3PointAngular object in model space
    Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
    ' Set precision so that degrees are visible
    DimPointAngularObj.TextPrecision = acDimPrecisionFour
    ' Read and display current decimal separator
    MsgBox "The decimal separator for this object is currently set to: [" & DimPointAngularObj.DecimalSeparator & "]"
    ' Alter the decimal separator property for this object
    oldSeparator = DimPointAngularObj.DecimalSeparator
    newSeparator = InputBox("Enter a new decimal separator", "Change Decimal Separator", oldSeparator)
    If newSeparator = "" Then
        Exit Sub
    Else
        ' Set new decimal separator, making sure to use only one character
        DimPointAngularObj.DecimalSeparator = Left(newSeparator, 1)
    End If
    MsgBox "The decimal separator for this object is now set to: [" & DimPointAngularObj.DecimalSeparator & "]"
(defun c:Example_DecimalSeparator()
    ;; This example creates a Dim3PointAngular object in model space
    ;; and allows the user to change the decimal separator appearance
    ;; using the DecimalSeparator property
    ;; Define the new Dim3PointAngular object
    (setq AngleVertex (vlax-3d-point 0 0 0)
          FirstPoint (vlax-3d-point 2 2 0)
          SecondPoint (vlax-3d-point 1 4 0)
          TextPoint (vlax-3d-point 6 6 0))
    ;; Create the new Dim3PointAngular object in model space
    (setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
    ;; Set precision so that degrees are visible
    (vla-put-TextPrecision DimPointAngularObj acDimPrecisionFour)
    (vla-ZoomAll acadObj)
    ;; Read and display current decimal separator
    (alert (strcat "The decimal separator for this object is currently set to: [" (vla-get-DecimalSeparator DimPointAngularObj) "]"))
    ;; Alter the decimal separator property for this object
    (setq oldSeparator (vla-get-DecimalSeparator DimPointAngularObj))
    (setq newSeparator (getstring "\nEnter a new decimal separator: "))
    (if (/= newSeparator "")
        ;; Set new decimal separator, making sure to use only one character
        (vla-put-DecimalSeparator DimPointAngularObj newSeparator)
    (alert (strcat "The decimal separator for this object is now set to: [" (vla-get-DecimalSeparator DimPointAngularObj) "]"))
GMT+8, 2026-11-4 22:09
