AutoCAD 2024 开发者帮助
CustomDictionary 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 1161| 评论: 0|原作者: admin|来自: AutoCAD
指定要使用的自定义词典(如果有)。
object.CustomDictionary
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
要使用的自定义词典。
此特性包含 AutoCAD 任务的自定义字典的驱动器、路径和文件名。
Sub Example_CustomDictionary()
    ' CustomDictionary. It then changes the value, and finally
    Dim currCustomDictionary As String
    Dim newCustomDictionary As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current CustomDictionary value
    currCustomDictionary = preferences.Files.CustomDictionary
    MsgBox "The current value for CustomDictionary is " & currCustomDictionary, vbInformation, "CustomDictionary Example"
    ' Change the value for CustomDictionary
    newCustomDictionary = "TestCustomDictionary.cus"
    preferences.Files.CustomDictionary = newCustomDictionary
    MsgBox "The new value for CustomDictionary is " & newCustomDictionary, vbInformation, "CustomDictionary Example"
    ' Reset CustomDictionary to its original value
    preferences.Files.CustomDictionary = currCustomDictionary
    MsgBox "The CustomDictionary value is reset to " & currCustomDictionary, vbInformation, "CustomDictionary Example"
(defun c:Example_CustomDictionary()
    ;; CustomDictionary. It then changes the value, and finally
    ;; Retrieve the current CustomDictionary value
    (setq currCustomDictionary (vla-get-CustomDictionary (vla-get-Files preferences)))
    (alert (strcat "The current value for CustomDictionary is " currCustomDictionary))
    ;; Change the value for CustomDictionary
    (setq newCustomDictionary "TestCustomDictionary.cus")
    (vla-put-CustomDictionary (vla-get-Files preferences) newCustomDictionary)
    (alert (strcat "The new value for CustomDictionary is " newCustomDictionary))
    ;; Reset CustomDictionary to its original value
    (vla-put-CustomDictionary (vla-get-Files preferences) currCustomDictionary)
    (alert (strcat "The CustomDictionary value is reset to " currCustomDictionary))
GMT+8, 2026-11-7 06:25
