AutoCAD 2024 开发者帮助
CreateBackup 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 899| 评论: 0|原作者: admin|来自: AutoCAD
指定备份文件的使用。
object.CreateBackup
类型:PreferencesOpenSave
此属性应用于的对象。
只读:
类型:布尔
  • True:创建备份文件。
  • False:不会创建备份文件(即使对于完整保存也是如此)。
此属性的初始值为 。True
此属性通过创建备份文件 (.bak) 来提高增量保存的速度。操作系统复制文件数据以为大型图形创建备份文件,这需要大部分增量保存时间。
谨慎:如果出现问题(例如在保存过程中断电),图形数据可能会丢失。
注意:此属性的值存储在 ISAVEBAK 系统变量中。
Sub Example_CreateBackup()
    ' CreateBackup. It then changes the value, and finally
    Dim currCreateBackup As Boolean
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current CreateBackup value
    currCreateBackup = preferences.OpenSave.CreateBackup
    MsgBox "The current value for CreateBackup is " & preferences.OpenSave.CreateBackup, vbInformation, "CreateBackup Example"
    ' Change the value for CreateBackup
    preferences.OpenSave.CreateBackup = Not (currCreateBackup)
    MsgBox "The new value for CreateBackup is " & preferences.OpenSave.CreateBackup, vbInformation, "CreateBackup Example"
    ' Reset CreateBackup to its original value
    preferences.OpenSave.CreateBackup = currCreateBackup
    MsgBox "The CreateBackup value is reset to " & preferences.OpenSave.CreateBackup, vbInformation, "CreateBackup Example"
(defun c:Example_CreateBackup()
    ;; CreateBackup. It then changes the value, and finally
    ;; Retrieve the current CreateBackup value
    (setq currCreateBackup (vla-get-CreateBackup (vla-get-OpenSave preferences)))
    (alert (strcat "The current value for CreateBackup is " (if (= currCreateBackup :vlax-true) "True" "False")))
    ;; Change the value for CreateBackup
    (setq newCreateBackup (if (= currCreateBackup :vlax-true) :vlax-false :vlax-true))
    (vla-put-CreateBackup (vla-get-OpenSave preferences) newCreateBackup)
    (alert (strcat "The new value for CreateBackup is " (if (= newCreateBackup :vlax-true) "True" "False")))
    ;; Reset CreateBackup to its original value
    (vla-put-CreateBackup (vla-get-OpenSave preferences) currCreateBackup)
    (alert (strcat "The CreateBackup value is reset to " (if (= currCreateBackup :vlax-true) "True" "False")))
GMT+8, 2026-9-14 18:13
