AutoCAD 2024 开发者帮助
ControlPoints 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 952| 评论: 0|原作者: admin|来自: AutoCAD
指定样条的控制点。
object.ControlPoints
类型:样条曲线
此属性应用于的对象。
只读:不
类型:变体(双打数组)
样条曲线的 3D WCS 控制点数组。
您可以使用属性了解样条曲线具有多少个控制点。NumberOfControlPoints
Sub Example_ControlPoints()
    ' This example creates a Spline object in model space, reads the control points
    ' of the Spline and then modifies the control points of the Spline.
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double, endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    Dim UserMessage As String
    Dim ControlPoints As Variant
    Dim iCount As Long, iPoint As Integer
    ' Define the Spline object
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 0: fitPoints(1) = 0: fitPoints(2) = 0
    fitPoints(3) = 5:   fitPoints(4) = 5: fitPoints(5) = 0
    fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    ' Create new Spline object
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ' Display control points for this Spline
    GoSub DISPLAYPOINTS
    ' Modify control points for this Spline
    ControlPoints(0) = 3
    splineObj.ControlPoints = ControlPoints
    ' Display new control points for this Spline
    GoSub DISPLAYPOINTS
    Exit Sub
DISPLAYPOINTS:
    ControlPoints = splineObj.ControlPoints
    ' Display in groups of three
    UserMessage = ""
    iPoint = 0
    For iCount = 0 To UBound(ControlPoints) Step 3
        iPoint = iPoint + 1
        UserMessage = UserMessage & iPoint & ")" & vbTab
        UserMessage = UserMessage & ControlPoints(iCount)
        UserMessage = UserMessage & ", " & ControlPoints(iCount + 1)
        UserMessage = UserMessage & ", " & ControlPoints(iCount + 2)
        UserMessage = UserMessage & vbCrLf
    Next
    MsgBox "The " & splineObj.NumberOfControlPoints & " Spline control points are: " & vbCrLf & vbCrLf & UserMessage
    Return
(defun c:Example_ControlPoints()
    ;; This example creates a Spline object in model space, reads the control points
    ;; of the Spline and then modifies the control points of the Spline.
    ;; Define the Spline object
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(0 0 0
				     5 5 0
				     10 0 0
    ;; Create new Spline object
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    ;; Display control points for this Spline
    (setq ControlPoints (vlax-variant-value (vla-get-ControlPoints splineObj)))
    ;; Display in groups of three
    (setq UserMessage ""
          iPoint 0
	  iCount 0)
    (while (>= (vlax-safearray-get-u-bound ControlPoints 1) iCount)
        (setq iPoint (1+ iPoint))
        (setq UserMessage (strcat UserMessage (itoa iPoint) ")  "
                                  (rtos (nth iCount (vlax-safearray->list ControlPoints)) 2) ", "
                                  (rtos (nth (+ iCount 1) (vlax-safearray->list ControlPoints)) 2) ", "
                                  (rtos (nth (+ iCount 2) (vlax-safearray->list ControlPoints)) 2) "\n"
        (setq iCount (+ iCount 3))
    (alert (strcat "The " (itoa (vla-get-NumberOfControlPoints splineObj)) " Spline control points are: " "\n\n" UserMessage))
    ;; Modify control points for this Spline
    (setq newFitPoint (vlax-3d-point 8 2 0))
    (vla-AddFitPoint splineObj 3 newFitPoint)
    ;; Display new control points for this Spline
          iPoint 0
	  iCount 0)
GMT+8, 2026-11-4 22:10
