Comment 属性 (ActiveX)
指定要包含在数字签名中的注释。 支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持 属性值只读:不 类型:字符串 要包含在数字签名中的注释。 言论没有其他评论。 例子VBA: Sub Example_Comment()
' This example attaches a digital signature and accompanying data to a file,
' and saves the file.
Dim sp As AcadSecurityParams
Set sp = GetInterfaceObject("AutoCAD.SecurityParams." & Left(AcadApplication.Version, 2))
' Attach a digital signature and timestamp it
sp.Action = AcadSecurityParamsType.ACADSECURITYPARAMS_SIGN_DATA + _
AcadSecurityParamsType.ACADSECURITYPARAMS_ADD_TIMESTAMP
' Certificate details follow
sp.Subject = "Thawte Freemail Member"
sp.Issuer = "Personal Freemail RSA 2000.8.30"
sp.SerialNumber = "073848"
sp.Comment = "This is now signed"
sp.TimeServer = "NIST(time.nist.gov)"
ThisDrawing.SaveAs "C:\MyDrawing.dwg", , sp
可视化 LISP: (vl-load-com)
(defun c:Example_Comment()
;; This example attaches a digital signature and accompanying data to a file,
;; and saves the file.
sp (vla-GetInterfaceObject acadObj (strcat "AutoCAD.SecurityParams." (substr (getvar "ACADVER") 1 2))))
(vla-put-Visible acadObj :vlax-true)
;; Attach a digital signature and timestamp it
(vla-put-Action sp (+ ACADSECURITYPARAMS_SIGN_DATA ACADSECURITYPARAMS_ADD_TIMESTAMP))
;; Certificate details follow
(vla-put-Subject sp "Thawte Freemail Member")
(vla-put-Issuer sp "Personal Freemail RSA 2000.8.30")
(vla-put-SerialNumber sp "073848")
(vla-put-Comment sp "This is now signed")
(vla-put-TimeServer sp "NIST(time.nist.gov)")
(vla-SaveAs doc "C:\\MyDrawing.dwg" acNative sp)
(vlax-release-object sp)
GMT+8, 2026-10-23 13:48
