AutoCAD 2024 开发者帮助
ColorIndex 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 857| 评论: 0|原作者: admin|来自: AutoCAD
指定颜色索引。
object.ColorIndex
类型:AcCmColor
此属性应用于的对象。
只读:不
类型:枚举acColor
默认颜色名称为 。使用介于 0 到 256 之间的颜色索引号,或此处列出的常量之一:acByLayer
  • acByBlock
  • acByLayer(对对象无效)Layer
  • acRed
  • acYellow
  • acGreen
  • acCyan
  • acBlue
  • acMagenta
  • acWhite
Sub Example_ColorIndex()
    'This example draws a circle and
    'returns the closest color index.
    Dim cir As AcadCircle
    Dim pt(0 To 2) As Double
    Set cir = ThisDrawing.modelSpace.AddCircle(pt, 2)
    Dim col As AcadAcCmColor
    Set col = cir.TrueColor
    col.SetRGB 125, 175, 235
    cir.TrueColor = col
    ZoomAll
    Dim retCol As AcadAcCmColor
    Set retCol = cir.TrueColor
    If col.ColorMethod = AutoCAD.acColorMethodByRGB Then
        MsgBox "Closest ColorIndex=" & col.ColorIndex
    End If
(defun c:Example_ColorIndex()
    ;;This example draws a circle and
    ;;returns the closest color index.
          doc (vla-get-ActiveDocument acadObj))
    (setq pt (vlax-3d-point 0 0 0))
    (setq modelSpace (vla-get-ModelSpace doc)
          cir (vla-AddCircle modelSpace pt 2)
          col (vla-get-TrueColor cir))
    (vla-SetRGB col 125 175 235)
    (vla-put-TrueColor cir col)
    (vla-ZoomAll acadObj)
    (setq retCol (vla-get-TrueColor cir))
    (if (= (vla-get-ColorMethod col) acColorMethodByRGB)
        (alert (strcat "Closest ColorIndex=" (itoa (vla-get-ColorIndex col))))
GMT+8, 2026-10-23 07:58
