AutoCAD 2024 开发者帮助
ColorBookPath 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 901| 评论: 0|原作者: admin|来自: AutoCAD
设置颜色书路径。
object.ColorBookPath
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
颜色书路径。
Sub Example_ColorBookPath()
    'This example changes the color book path
    'and then sets it to its original string
    Dim pref As AutoCAD.AcadPreferencesFiles
    Set pref = AcadApplication.Preferences.Files
    Dim defCBPath As String
    Dim changedCBPath As String
    defCBPath = pref.ColorBookPath
    MsgBox "The current color book path is " & defCBPath
    pref.ColorBookPath = "c:\winnt;c:\temp"
    changedCBPath = pref.ColorBookPath
    MsgBox "The changed color book path is " & changedCBPath
    pref.ColorBookPath = defCBPath
(defun c:Example_ColorBookPath()
    ;; This example changes the color book path
    ;; and then sets it to its original string
    (setq pref (vla-get-Files (vla-get-Preferences acadObj)))
    (setq defCBPath (vla-get-ColorBookPath pref))
    (alert (strcat "The current color book path is " defCBPath))
    (vla-put-ColorBookPath pref "c:\\winnt;c:\\temp")
    (setq changedCBPath (vla-get-ColorBookPath pref))
    (alert (strcat "The changed color book path is " changedCBPath))
    (vla-put-ColorBookPath pref defCBPath)
GMT+8, 2026-11-1 07:09
