AutoCAD 2024 开发者帮助
Closed 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 1071| 评论: 0|原作者: admin|来自: AutoCAD
Closed 属性 (ActiveX)
指定 3D 折线、轻量级折线、放样曲面、折线或样条是打开还是闭合。
object.Closed
类型:3DPolyline、LoftedSurface、LWPolyline、折线、样条
此属性应用于的对象。
只读:
  • 否(对象除外):AutoCADSpline
  • 否(对象和对象除外):AutoCAD LTSplineLoftedSurface
类型:布尔
  • True:对象已关闭。
  • False:对象处于打开状态(默认)。
开放的 3D 折线
闭合的 3D 折线
如果确定其轮廓的横截面曲线闭合,则放样曲面闭合。例如,如果在放样轮廓中使用圆弧,则生成的曲面是开放的。如果使用闭合曲线(如圆)进行放样,则生成的曲面是闭合的。
Sub Example_Closed()
    ' This example creates a polyline and then toggles the
    ' setting to Closed.
    Dim plineObj As AcadPolyline
    Dim closedState As String
    ' Create the polyline
    Dim points(8) As Double
    points(0) = 3: points(1) = 7: points(2) = 0
    points(3) = 9: points(4) = 2: points(5) = 0
    points(6) = 3: points(7) = 5: points(8) = 0
    Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
    ' Set the closed property to True
    plineObj.Closed = True      ' Close Polyline
    ThisDrawing.Regen (True)
    GoSub DISPLAY
    ' Open the PolyLine by setting the closed property to False
    plineObj.Closed = False      ' Open Polyline
    GoSub DISPLAY
    Exit Sub
DISPLAY:
    ' Retrieve and display the Closed property
    closedState = IIf(plineObj.Closed, "Closed", "Open")
    MsgBox "The new Polyline is: " & closedState, vbInformation, "Closed Example"
    Return
(defun c:Example_Closed()
    ;; This example creates a polyline and then toggles the
    ;; setting to Closed.
    ;; Create the polyline
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill points '(3 7 0
				  9 2 0
				  3 5 0
    (setq plineObj (vla-AddPolyline modelSpace points))
    ;; Set the closed property to True
    (vla-put-Closed plineObj :vlax-true)      ;; Close Polyline
    (vla-Regen doc :vlax-true)
    ;; Retrieve and display the Closed property
    (setq closedState (if (= (vla-get-Closed plineObj) :vlax-true) "Closed" "Open"))
    (alert (strcat "The new Polyline is: " closedState))
    ;; Open the PolyLine by setting the closed property to False
    (vla-put-Closed plineObj :vlax-false)      ;; Open Polyline
GMT+8, 2026-10-22 08:59
