AutoCAD 2024 开发者帮助
BackgroundFill 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 679| 评论: 0|原作者: admin|来自: AutoCAD
指定多行文本是否具有背景填充。
object.BackgroundFill
类型:GeoPositionMarkerMText
此属性应用于的对象。
只读:
类型:布尔
  • True:启用后台填充。
  • False:背景填充已禁用。
MText:此属性中包含的值是“属性”选项板中的“背景掩码”属性。
Sub Example_BackgroundFill()
    ' This example creates a circle and an MText object, and masks part of the
    ' circle with the MText object
    'Draw a circle
    Dim circleObj As AcadCircle
    Dim CircleReference(0 To 2) As Double
    Dim radius As Double
    CircleReference(0) = 0
    CircleReference(1) = 0
    CircleReference(2) = 0
    radius = 5
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(CircleReference, radius)
    ZoomAll
    MsgBox "A circle has been drawn."
    'Create an MText object with the BackgroundFill property set to True
    Dim MTextObj As AcadMText
    Dim width As Double
    Dim text As String
    width = 10
    text = "This is the text for the MText object"
    Set MTextObj = ThisDrawing.ModelSpace.AddMText(CircleReference, width, text)
    MTextObj.BackgroundFill = True
    ZoomAll
(defun c:Example_BackgroundFill()
    ;; This example creates a circle and an MText object, and masks part of the
    ;; circle with the MText object
    ;; Draw a circle
    (setq CircleReference (vlax-3d-point 0 0 0)
          radius 0.5)
    (setq circleObj (vla-AddCircle modelSpace CircleReference radius))
    (vla-ZoomAll acadObj)
    (alert "A circle has been drawn.")
    ;; Create an MText object with the BackgroundFill property set to True
    (setq width 5
          text "This is the text for the MText object")
    (setq MTextObj (vla-AddMText modelSpace CircleReference width text))
    (vla-put-AttachmentPoint MTextObj 5)
    (vla-put-InsertionPoint MTextObj CircleReference)
    (vla-put-BackgroundFill MTextObj :vlax-true)
GMT+8, 2026-9-19 14:22
