AutoAudit 属性 (ActiveX)
指定 AutoCAD 在渲染 DXFIN 或 DXBIN 交换命令后是否应执行审核。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_AutoAudit()
' AutoAudit. It then changes the value, and finally
Dim currAutoAudit As Boolean
Dim newAutoAudit As Boolean
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current AutoAudit value
currAutoAudit = preferences.OpenSave.AutoAudit
MsgBox "The current value for AutoAudit is " & currAutoAudit, vbInformation, "AutoAudit Example"
' Toggle the value for AutoAudit
newAutoAudit = Not (currAutoAudit)
preferences.OpenSave.AutoAudit = newAutoAudit
MsgBox "The new value for AutoAudit is " & newAutoAudit, vbInformation, "AutoAudit Example"
' Reset AutoAudit to its original value
preferences.OpenSave.AutoAudit = currAutoAudit
MsgBox "The AutoAudit value is reset to " & currAutoAudit, vbInformation, "AutoAudit Example"
可视化 LISP: (vl-load-com)
(defun c:Example_AutoAudit()
;; AutoAudit. It then changes the value, and finally
;; Retrieve the current AutoAudit value
(setq currAutoAudit (vla-get-AutoAudit (vla-get-OpenSave preferences)))
(alert (strcat "The current value for AutoAudit is " (if (= currAutoAudit :vlax-true) "True" "False")))
;; Toggle the value for AutoAudit
(setq newAutoAudit (if (= currAutoAudit :vlax-true) :vlax-false :vlax-true))
(vla-put-AutoAudit (vla-get-OpenSave preferences) newAutoAudit)
(alert (strcat "The new value for AutoAudit is " (if (= newAutoAudit :vlax-true) "True" "False")))
;; Reset AutoAudit to its original value
(vla-put-AutoAudit (vla-get-OpenSave preferences) currAutoAudit)
(alert (strcat "The AutoAudit value is reset to " (if (= currAutoAudit :vlax-true) "True" "False")))
GMT+8, 2026-10-22 13:01
