AutoCAD 2024 开发者帮助
AltUnitsFormat 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 759| 评论: 0|原作者: admin|来自: AutoCAD
指定除角度外的所有尺寸的备用单位的单位格式。
object.AltUnitsFormat
类型:DimAlignedDimArcLengthDimDiametricDimOrdinateDimRadial、DimRadialLargeDimRotated
此属性应用于的对象。
只读:
类型:枚举acDimUnits
  • acDimScientific
  • acDimDecimal
  • acDimEngineering
  • acDimArchitecturalStacked
  • acDimFractionalStacked
  • acDimFractional
  • acDimWindowsDesktop
此属性的初始值为 。acDimDecimal
注意:此属性将覆盖给定维度的 DIMALTU 系统变量的值。
Sub Example_AltUnitsFormat()
    ' uses AltUnitsFormat to cycle through some common unit formats
    ' for the alternate dimension
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point1(0) = 0: point1(1) = 5: point1(2) = 0
    point2(0) = 5.12345678: point2(1) = 5: point2(2) = 0
    ' Enable unit display of alternate units
    dimObj.AltUnits = True
    dimObj.AltUnitsFormat = acDimScientific     ' Change format to Scientific
    MsgBox "The alternate dimension units are now set to Scientific"
    dimObj.AltUnitsFormat = acDimDecimal        ' Change format to Decimal
    MsgBox "The alternate dimension units are now set to Decimal"
    dimObj.AltUnitsFormat = acDimArchitectural  ' Change format to Architectural
    MsgBox "The alternate dimension units are now set to Architectural"
    dimObj.AltUnitsFormat = acDimWindowsDesktop ' Change format to Windows Desktop
    MsgBox "The alternate dimension units are now set to Windows Desktop"
(defun c:Example_AltUnitsFormat()
    ;; uses AltUnitsFormat to cycle through some common unit formats
    ;; for the alternate dimension
    ;; Define the dimension
    (setq point1 (vlax-3d-point 0 5 0)
          point2 (vlax-3d-point 5.12345678 5 0)
    (vla-ZoomAll acadObj)
    ;; Enable unit display of alternate units
    (vla-put-AltUnits dimObj :vlax-true)
    (vla-put-AltUnitsFormat dimObj acDimScientific)     ;; Change format to Scientific
    (alert "The alternate dimension units are now set to Scientific.")
    (vla-put-AltUnitsFormat dimObj acDimDecimal)        ;; Change format to Decimal
    (alert "The alternate dimension units are now set to Decimal.")
    (vla-put-AltUnitsFormat dimObj acDimArchitectural)  ;; Change format to Architectural
    (alert "The alternate dimension units are now set to Architectural.")
    (vla-put-AltUnitsFormat dimObj acDimWindowsDesktop) ;; Change format to Windows Desktop
    (alert "The alternate dimension units are now set to Windows Desktop.")
GMT+8, 2026-9-15 13:31
