AutoCAD 2024 开发者帮助
AltToleranceSuppressLeadingZeros 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 898| 评论: 0|原作者: admin|来自: AutoCAD
指定禁止在备用维度值中显示前导零。
object.AltToleranceSuppressLeadingZeros
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:禁止在交替维度中显示前导零。例如,0.5000 变为 .5000。
  • False:不要在交替维度中隐藏前导零。
此属性的初始值为 。False
注意:此属性将覆盖给定维度的 DIMALTTZ 系统变量的值。
Sub Example_AltToleranceSuppressLeadingZeros()
   ' uses AltToleranceSuppressLeadingZeros to toggle the display of leading zeros
   ' in the alternate dimension tolerance display
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 5.01: point2(1) = 5: point2(2) = 0
    ' Set up alternate unit tolerance display
    dimObj.AltUnits = True
    dimObj.ToleranceDisplay = acTolLimits
Toggle:
    Select Case MsgBox("Press OK to toggle the display of leading zeros in the alternate dimension tolerance", vbOKCancel)
        Case vbOK
            ' Toggle the display of leading zeros for the alternate dimension tolerance value
            dimObj.AltToleranceSuppressLeadingZeros = Not (dimObj.AltToleranceSuppressLeadingZeros)
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
(defun c:Example_AltToleranceSuppressLeadingZeros()
    ;; uses AltToleranceSuppressLeadingZeros to toggle the display of leading zeros
    ;; in the alternate dimension tolerance display
    ;; Define the dimension
          point2 (vlax-3d-point 5.01 5 0)
    ;; Set up alternate unit tolerance display
    (vla-put-AltUnits dimObj :vlax-true)
    (vla-put-ToleranceDisplay dimObj acTolLimits)
    (vla-ZoomAll acadObj)
    ;; Toggle the display of leading zeros for the alternate dimension tolerance value
    (vla-put-AltToleranceSuppressLeadingZeros dimObj (if (= (vla-get-AltToleranceSuppressLeadingZeros dimObj) :vlax-true) :vlax-false :vlax-true))
    (alert "Suppression of leading zeros in the alternate dimension tolerance toggled.")
    ;; Toggle the display of leading zeros for the alternate dimension tolerance value back to previous state
    (alert "Suppression of leading zeros in the alternate dimension tolerance toggled back.")
GMT+8, 2026-11-3 20:50
