AutoCAD 2024 开发者帮助
AltTabletMenuFile 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 1029| 评论: 0|原作者: admin|来自: AutoCAD
指定备用菜单与标准 AutoCAD 数位板菜单交换的路径。
object.AltTabletMenuFile
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
备用平板电脑菜单路径。
仅当使用数字化器时,此属性才适用。
Sub Example_AltTabletMenuFile()
    ' AltTabletMenuFile. It then changes the value, and finally
    Dim currAltTabletMenuFile As String
    Dim newAltTabletMenuFile As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current AltTabletMenuFile value
    currAltTabletMenuFile = preferences.Files.AltTabletMenuFile
    If currAltTabletMenuFile = "" Then
        MsgBox "AltTabletMenuFile is not currently set.", vbInformation, "AltTabletMenuFile Example"
    Else
        MsgBox "The current value for AltTabletMenuFile is " & currAltTabletMenuFile, vbInformation, "AltTabletMenuFile Example"
    End If
    ' Change the value for AltTabletMenuFile
    newAltTabletMenuFile = "d:\acad\support\acad"
    preferences.Files.AltTabletMenuFile = newAltTabletMenuFile
    MsgBox "The new value for AltTabletMenuFile is " & newAltTabletMenuFile, vbInformation, "AltTabletMenuFile Example"
    ' Reset AltTabletMenuFile to its original value
    preferences.Files.AltTabletMenuFile = currAltTabletMenuFile
        MsgBox "AltTabletMenuFile is reset to Null.", vbInformation, "AltTabletMenuFile Example"
    Else
        MsgBox "The AltTabletMenuFile value is reset to " & currAltTabletMenuFile, vbInformation, "AltTabletMenuFile Example"
    End If
(defun c:Example_AltTabletMenuFile()
    ;; AltTabletMenuFile. It then changes the value, and finally
    ;; Retrieve the current AltTabletMenuFile value
    (setq currAltTabletMenuFile (vla-get-AltTabletMenuFile (vla-get-Files preferences)))
    (if (= currAltTabletMenuFile "")
        (alert "AltTabletMenuFile is not currently set.")
        (alert (strcat "The current value for AltTabletMenuFile is " currAltTabletMenuFile))
    ;; Change the value for AltTabletMenuFile
    (vla-put-AltTabletMenuFile (vla-get-Files preferences) "C:\\AutoCAD\\acad")
    (alert (strcat "The new value for AltTabletMenuFile is " (vla-get-AltTabletMenuFile (vla-get-Files preferences))))
    ;; Reset AltTabletMenuFile to its original value
    (vla-put-AltTabletMenuFile (vla-get-Files preferences) currAltTabletMenuFile)
        (alert "AltTabletMenuFile is reset to Null.")
        (alert (strcat "The AltTabletMenuFile value is reset to " (vla-get-AltTabletMenuFile (vla-get-Files preferences))))
GMT+8, 2026-10-23 19:46
