AutoCAD 2024 开发者帮助
AltSuppressTrailingZeros 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 1052| 评论: 0|原作者: admin|来自: AutoCAD
指定禁止在备用维度值中隐藏尾随零。
object.AltSuppressTrailingZeros
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:在交替维度中隐藏尾随零。例如,12.5000 变为 12.5。
  • False:不要在交替维度中隐藏尾随零。
此属性的初始值为 False。
注意:此属性将覆盖给定维度的 DIMALTZ 系统变量的值。
Sub Example_AltSuppressTrailingZeros()
   ' uses AltSuppressTrailingZeros to toggle the display of trailing zeros
   ' in the alternate dimension display
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 7: point2(1) = 5: point2(2) = 0
    ' Enable alternate unit display
    dimObj.AltUnits = True
Toggle:
    Select Case MsgBox("Press OK to toggle the display of trailing zeros in the alternate dimension", vbOKCancel)
        Case vbOK
            ' Toggle the display of trailing zeros for the alternate dimension value
            dimObj.AltSuppressTrailingZeros = Not (dimObj.AltSuppressTrailingZeros)
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
(defun c:Example_AltSuppressTrailingZeros()
    ;; uses AltSuppressTrailingZeros to toggle the display of trailing zeros
    ;; in the alternate dimension display
    ;; Define the dimension
          point2 (vlax-3d-point 7 5 0)
    ;; Enable alternate unit display
    (vla-put-AltUnits dimObj :vlax-true)
    ;; Set up alternate unit tolerance display
    (setq originalValue (vla-get-AltSuppressTrailingZeros dimObj))
    (vla-put-AltSuppressTrailingZeros dimObj :vlax-true)
    (vla-ZoomAll acadObj)
    (alert "Toggling the display of trailing zeros in the alternate dimension.")
    ;; Toggle the display of trailing zeros for the alternate dimension tolerance value
    (vla-put-AltSuppressTrailingZeros dimObj (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-AltSuppressTrailingZeros dimObj))
    (alert "Toggling the display of trailing zeros in the alternate dimension to original value.")
    (vla-put-AltSuppressTrailingZeros dimObj (if (= newValue :vlax-true) :vlax-false :vlax-true))
GMT+8, 2026-10-24 22:29
