AutoCAD 2024 开发者帮助
AltRoundDistance 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 1129| 评论: 0|原作者: admin|来自: AutoCAD
指定备用单位的舍入。
object.AltRoundDistance
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:双
一个正实数,表示要将距离舍入到的值。初始值为 0.00。
如果该属性处于打开状态,则此属性将定义要将距离舍入到的数字。AltUnits
注意:此属性将覆盖给定维度的 DIMALTRND 系统变量的值。
Sub Example_AltRoundDistance()
   ' uses AltRoundDistance to set the alternate unit display
   ' of the dimension to rounded values
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 10.123: point2(1) = 5: point2(2) = 0
    ' Enable alternate unit display
    dimObj.AltUnits = True
    MsgBox "Press any key to round the alternate dimension unit display to .5"
    ' Round the distance of the alternate dimension to 0.50 of a unit
    dimObj.AltRoundDistance = 0.5
    MsgBox "Alternate dimension units have been rounded to: " & dimObj.AltRoundDistance
(defun c:Example_AltRoundDistance()
    ;; uses AltRoundDistance to set the alternate unit display
    ;; of the dimension to rounded values
    ;; Define the dimension
          point2 (vlax-3d-point 10.123 5 0)
    ;; Enable alternate unit display
    (vla-put-AltUnits dimObj :vlax-true)
    (vla-ZoomAll acadObj)
    (alert "Round the alternate dimension unit display to .5")
    ;; Round the distance of the alternate dimension to 0.50 of a unit
    (vla-put-AltRoundDistance dimObj 0.5)
    (alert (strcat "Alternate dimension units have been rounded to: " (rtos (vla-get-AltRoundDistance dimObj) 2 4)))
GMT+8, 2026-10-24 12:09
