AutoCAD 2024 开发者帮助
ActiveLayout 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 989| 评论: 0|原作者: admin|来自: AutoCAD
指定活动布局。
object.ActiveLayout
类别: 文档
此属性应用于的对象。
只读:不
类型: 布局
图形当前处于活动状态的布局。
Sub Example_ActiveLayout()
    ' This example cycles through the documents collection
    ' and uses the ActiveLayout object to list the active layout
    ' for all open documents.
    Dim DOC As AcadDocument
    Dim msg As String
    ' If there are no open documents, then exit
    If Documents.Count = 0 Then
        MsgBox "There are no open documents!"
        Exit Sub
    End If
    msg = vbCrLf   ' Start with a space
    ' Cycle through documents and determine the active layout name using the
    ' ActiveLayout property of the document object
    For Each DOC In Documents
        msg = msg & DOC.WindowTitle & ": " & DOC.ActiveLayout.Name & vbCrLf
    Next
    ' Display results
    MsgBox "The active layouts for the open drawings are: " & msg
(defun c:Example_ActiveLayout()
    ;; This example cycles through the documents collection
    ;; and uses the ActiveLayout object to list the active layout
    ;; for all open documents.
    (setq docs (vla-get-Documents acadObj))
    (setq msg "")
    ;; Cycle through the Documents collection and determine the active layout name using the
    ;; ActiveLayout property of the document object
    (vlax-for each-doc docs
        (setq msg (strcat msg (vla-get-WindowTitle each-doc) ": " (vla-get-Name (vla-get-ActiveLayout each-doc)) "\n"))
    ;; Display results
    (alert (strcat "The active layouts for the open drawings are: \n\n" msg))
GMT+8, 2026-10-23 07:58
