AutoCAD 2024 开发者帮助
UnloadDVB 方法 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 829| 评论: 0|原作者: admin|来自: AutoCAD
卸载指定的 AutoCAD VBA 项目文件。
支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持
object.UnloadDVB Name
类型: 应用
此方法应用到的对象。
名字
访问:仅输入
类型:字符串
要卸载的 .dvb 项目的名称。
返回值 (RetVal)
无返回值。
Sub Example_LoadDVB()
    ' This example loads a DVB file and runs a macro
    ' contained in the file using the RunMacro method.
    ' This example uses a DVB file named drawline.dvb.
    ' You should change the example to use a file on your computer.
    ' * Note: If you open a DVB file and then run the example to load it, there will be an error
    ' when the DVB file is unloaded.
    Dim FileName As String
    FileName = "c:\drawline.dvb"
    ' Load a sample VBA project DVB file
    LoadDVB FileName
    ' Run the drawline sample macro
    RunMacro "Module1.Drawline"
    ' Unload the drawline VBA project DVB file now.
    UnloadDVB FileName
    MsgBox "The DVB file has been run!"
(defun c:Example_LoadDVB()
    ;; This example loads a DVB file and runs a macro
    ;; contained in the file using the RunMacro method.
    ;; This example uses a DVB file named drawline.dvb.
    ;; You should change the example to use a file on your computer.
    ;; * Note: If you open a DVB file and then run the example to load it, there will be an error
    ;; when the DVB file is unloaded.
    (setq FileName (findfile ".\\Sample\\VBA\\drawline.dvb"))
    ;; Load a sample VBA project DVB file
    (vla-LoadDVB acadObj FileName)
    ;; Run the drawline sample macro
    (vla-RunMacro acadObj "Module1.Drawline")
    ;; Unload the drawline VBA project DVB file now.
    (vla-UnloadDVB acadObj FileName)
    (alert "The DVB file has been run!")
GMT+8, 2026-10-22 12:42
