AutoCAD 2024 开发者帮助
StartUndoMark 方法 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 1039| 评论: 0|原作者: admin|来自: AutoCAD
标记操作块的开始。
object.StartUndoMark
类别: 文档
此方法应用到的对象。
返回值 (RetVal)
无返回值。
此方法允许AutoCAD设置必要的环境,因此可以将此调用和调用之间完成的操作视为一组操作。EndUndoMark
Sub Example_StartUndoMark()
    ' This example creates a series of lines, each with an undo marker
    ' defined for it. After lines are created, you can switch to AutoCAD and type
    ' the Undo command, and only one line at a time will be undone. If StartUndoMark
    ' call is not made, an undo in AutoCAD will undo all the lines at once.
    Dim line As AcadLine
    Dim stPnt(0 To 2) As Double
    Dim endPnt(0 To 2) As Double
    stPnt(0) = 1: stPnt(1) = 2: stPnt(2) = 0
    endPnt(0) = 2: stPnt(1) = 1: stPnt(2) = 0
    ' Create the lines
    Dim j As Integer
    For j = 0 To 3
        ThisDrawing.StartUndoMark
        Set line = ThisDrawing.ModelSpace.AddLine(stPnt, endPnt)
        stPnt(0) = stPnt(0) + 3
        endPnt(0) = endPnt(0) + 3
        ThisDrawing.EndUndoMark
    Next
    ZoomAll
(defun c:Example_StartUndoMark()
    ;; This example creates a series of lines, each one with an undo marker
    ;; defined for it. After lines are created you can switch to AutoCAD and type
    ;; the Undo command, and only one line at a time will be undone. If StartUndoMark
    ;; call is not made, an undo in AutoCAD will undo all the lines at once.
    (setq stPnt (vlax-3d-point 1 2 0)
          endPnt (vlax-3d-point 2 1 0))
    ;; Create the lines
    (setq j 0)
    (while (>= 3 j)
        (vla-StartUndoMark doc)
        (setq line (vla-AddLine modelSpace stPnt endPnt))
        (vlax-safearray-put-element (vlax-variant-value stPnt) 0 (+ (vlax-safearray-get-element (vlax-variant-value stPnt) 0) 3))
        (vlax-safearray-put-element (vlax-variant-value endPnt) 0 (+ (vlax-safearray-get-element (vlax-variant-value endPnt) 0) 3))
        (setq j (1+ j))
        (vla-EndUndoMark doc)
    (vla-ZoomAll acadObj)
GMT+8, 2026-10-22 11:09
