SetBackgroundColor2 方法 (ActiveX)
设置指定命名单元格样式的背景颜色值。 支持的平台:仅限 Windows 签名VBA: object.SetBackgroundColor2 bstrCellStyle, color
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_SetBackgroundColor2()
' the style name and other attributes.
Dim dictObj As AcadDictionary
' Get the current TableStyle object
Dim tableStyle As AcadTableStyle
Set tableStyle = dictObj.Item(ThisDrawing.GetVariable("CTABLESTYLE"))
Dim colCurrent As AcadAcCmColor, colRowCurrent As AcadAcCmColor, colNoneCurrent As Boolean
Set colCurrent = tableStyle.GetBackgroundColor2("Title")
Set colRowCurrent = tableStyle.GetColor2("Data")
colNoneCurrent = tableStyle.GetBackgroundColorNone(acHeaderRow)
MsgBox "Table colors " & vbLf & _
"Background ACI value = " & colCurrent.ColorIndex & vbLf & _
"Row Text ACI value = " & colRowCurrent.ColorIndex & vbLf & _
"Background None = " & colNoneCurrent
Dim col As AcadAcCmColor
Set col = tableStyle.GetBackgroundColor(acTitleRow)
col.SetRGB 0, 0, 255
tableStyle.SetBackgroundColor2 "Title", col
col.SetRGB 255, 0, 0
tableStyle.SetColor2 "Data", col
If colNoneCurrent = False Then
tableStyle.SetBackgroundColorNone acHeaderRow, True
Else
tableStyle.SetBackgroundColorNone acHeaderRow, False
End If
Dim colNew As AcadAcCmColor, colRowNew As AcadAcCmColor, colNoneNew As Boolean
Set colNew = tableStyle.GetBackgroundColor2("Title")
Set colRowNew = tableStyle.GetColor2("Data")
colNoneNew = tableStyle.GetBackgroundColorNone(acHeaderRow)
"Background ACI value = " & colNew.ColorIndex & vbLf & _
"Row Text ACI value = " & colRowNew.ColorIndex & vbLf & _
"Background None = " & colNoneNew
tableStyle.SetBackgroundColor2 "Title", colCurrent
tableStyle.SetColor2 "Data", colRowCurrent
tableStyle.SetBackgroundColorNone acHeaderRow, colNoneCurrent
MsgBox "Reset the table style back to its original values."
可视化 LISP: (vl-load-com)
(defun c:Example_SetBackgroundColor2()
;; the style name and other attributes.
doc (vla-get-ActiveDocument acadObj))
(setq dictionaries (vla-get-Dictionaries doc)
dictObj (vla-Item dictionaries "acad_tablestyle"))
;; Get the current TableStyle object
(setq tableStyle (vla-Item dictObj (vla-GetVariable doc "CTABLESTYLE")))
(setq colCurrent (vla-GetBackgroundColor2 tableStyle "Title")
colRowCurrent (vla-GetColor2 tableStyle "Data")
colNoneCurrent (vla-GetBackgroundColorNone tableStyle acHeaderRow))
(alert (strcat "Table colors \n"
"Background ACI value = " (itoa (vla-get-ColorIndex colCurrent)) "\n"
"Row Text ACI value = " (itoa (vla-get-ColorIndex colRowCurrent)) "\n"
"Background None = " (if (= colNoneCurrent :vlax-true) "True" "False")))
(setq col (vla-GetBackgroundColor2 tableStyle "Title"))
(vla-SetRGB col 0 0 255)
(vla-SetBackgroundColor2 tableStyle "Title" col)
(vla-SetRGB col 255 0 0)
(vla-SetColor2 tableStyle "Data" col)
(vla-SetBackgroundColorNone tableStyle acHeaderRow (if (= colNoneCurrent :vlax-true) :vlax-false :vlax-true))
(setq colNew (vla-GetBackgroundColor2 tableStyle "Title")
colRowNew (vla-GetColor2 tableStyle "Data")
colNoneNew (vla-GetBackgroundColorNone tableStyle acHeaderRow))
"Background ACI value = " (itoa (vla-get-ColorIndex colNew)) "\n"
"Row Text ACI value = " (itoa (vla-get-ColorIndex colRowNew)) "\n"
"Background None = " (if (= colNoneNew :vlax-true) "True" "False")))
(vla-SetBackgroundColor2 tableStyle "Title" colCurrent)
(vla-SetColor2 tableStyle "Data" colRowCurrent)
(vla-SetBackgroundColorNone tableStyle acHeaderRow colNoneCurrent)
(alert "Reset the table style back to its original values.")
GMT+8, 2026-11-4 22:08
