AutoCAD 2024 开发者帮助
RunMacro 方法 (ActiveX)
2024-5-18 19:07| 发布者: admin| 查看: 799| 评论: 0|原作者: admin|来自: AutoCAD
从 Application 对象运行 VBA 宏。
支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持
object.RunMacro MacroPath
类型: 应用
此方法应用到的对象。
宏路径
访问:仅输入
类型:字符串
一个字符串,表示要运行的宏的调用序列。调用序列必须具有以下语法,其中表示可选参数:[]
[Filename.dvb.][ProjectName.][ModuleName.]MacroName
注意:如果 Filename.dvb 后面跟着 ,则用感叹号而不是句点分隔名称,如以下示例所示:ProjectName
Filename.dvb!ProjectName
如果尚未加载指定的 Filename.dvb,则将加载该文件。如果未指定 Filename.dvb 的路径,则搜索 AutoCAD 搜索路径以查找该文件。如果未指定,则搜索所有当前加载的项目以查找宏。ProjectName
返回值 (RetVal)
无返回值。
若要将宏与弹出菜单或工具栏项相关联,请使用该属性。Macro
Sub Example_RunMacro()
    ' This example loads a DVB file and runs a macro
    ' contained in the file using the RunMacro method.
    ' This example uses a DVB file named drawline.dvb.
    ' You should change the example to use a file on your computer.
    ' * Note: If you open a DVB file and then run the example to load it, there will be an error
    ' when the DVB file is unloaded.
    Dim FileName As String
    FileName = "c:\drawline.dvb"
    ' Load a sample VBA project DVB file
    LoadDVB FileName
    ' Run the drawline sample macro
    RunMacro "Module1.Drawline"
    ' Unload the drawline VBA project DVB file now that we are done
    UnloadDVB FileName
    MsgBox "The DVB file has been run!"
(defun c:Example_RunMacro()
    ;; This example loads a DVB file and runs a macro
    ;; contained in the file using the RunMacro method.
    ;; This example uses a DVB file named drawline.dvb.
    ;; You should change the example to use a file on your computer.
    ;; * Note: If you open a DVB file and then run the example to load it, there will be an error
    ;; when the DVB file is unloaded.
    (setq fileName (findfile ".\\Sample\\VBA\\drawline.dvb"))
    ;; Load a sample VBA project DVB file
    (vla-LoadDVB acadObj fileName)
    ;; Run the drawline sample macro
    (vla-RunMacro acadObj "Module1.Drawline")
    ;; Unload the drawline VBA project DVB file now that we are done
    (vla-UnloadDVB acadObj fileName)
    (alert "The DVB file has been run!")
GMT+8, 2026-10-23 10:40
