AutoCAD 2024 开发者帮助
Rotate 方法 (ActiveX)
2024-5-18 19:07| 发布者: admin| 查看: 903| 评论: 0|原作者: admin|来自: AutoCAD
Rotate 方法 (ActiveX)
围绕基点旋转对象。
object.Rotate BasePoint, RotationAngle
类型:所有绘图对象、AttributeReference、尺寸
此方法应用到的对象。
基点
访问:仅输入
类型:变体(双打的三元素阵列)
3D WCS 坐标指定旋转轴定义为平行于 UCS 的 Z 轴的点。
旋转角度
访问:仅输入
类型:双
旋转物体的角度(以弧度为单位)。此角度决定了对象相对于其当前位置围绕基点旋转的距离。
返回值 (RetVal)
无返回值。
Sub Example_Rotate()
    ' This example creates a lightweight polyline
    ' and then rotates that polyline.
    ' Create the polyline
    Dim points(0 To 11) As Double
    points(0) = 1: points(1) = 2
    points(2) = 1: points(3) = 3
    points(4) = 2: points(5) = 3
    points(6) = 3: points(7) = 3
    points(8) = 4: points(9) = 4
    points(10) = 4: points(11) = 2
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    plineObj.Closed = True
    ZoomAll
    MsgBox "Rotate the polyline by 45 degrees.", , "Rotate Example"
    ' Define the rotation
    Dim basePoint(0 To 2) As Double
    Dim rotationAngle As Double
    basePoint(0) = 4: basePoint(1) = 4.25: basePoint(2) = 0
    rotationAngle = 0.7853981   ' 45 degrees
    ' Rotate the polyline
    plineObj.Rotate basePoint, rotationAngle
    ZoomAll
    MsgBox "Rotation completed.", , "Rotate Example"
(defun c:Example_Rotate()
    ;; This example creates a lightweight polyline
    ;; and then rotates that polyline.
    ;; Create the polyline
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 11)))
    (vlax-safearray-fill points '(1 1
                                  1 3
                                  2 3
                                  3 3
                                  4 4
                                  4 2
    (setq plineObj (vla-AddLightWeightPolyline modelSpace points))
    (vla-put-Closed plineObj :vlax-true)
    (vla-ZoomAll acadObj)
    (alert "Rotate the polyline by 45 degrees.")
    ;; Define the rotation
    (setq basePoint (vlax-3d-point 4 4.25 0)
          rotationAngle 0.7853981)   ;; 45 degrees
    ;; Rotate the polyline
    (vla-Rotate plineObj basePoint rotationAngle)
    (alert "Rotation completed.")
GMT+8, 2026-10-24 06:47
