Restore 方法 (ActiveX)
恢复一组图层属性设置。 支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持 返回值 (RetVal)无返回值。 言论该方法使用与保存的设置关联的属性来标识要恢复的图层属性。RestoreMask 例子VBA: Sub Example_RestoreLayerSettings()
' The following code restores color and linetype settings
' that were saved as "ColorLineType".
Dim oLSM As AcadLayerStateManager
Set oLSM = ThisDrawing.Application. _
GetInterfaceObject("AutoCAD.AcadLayerStateManager." & Left(AcadApplication.Version, 2))
oLSM.SetDatabase ThisDrawing.Database
oLSM.Restore "ColorLinetype"
可视化 LISP: (vl-load-com)
(defun c:Example_Restore()
;; The following code restores color and linetype settings
;; that were saved as "ColorLineType."
doc (vla-get-ActiveDocument acadObj))
;; Access the LayerStateManager object.
(setq oLSM (vla-GetInterfaceObject acadObj (strcat "AutoCAD.AcadLayerStateManager." (substr (getvar "ACADVER") 1 2))))
(vla-SetDatabase oLSM (vla-get-Database doc))
(vla-Restore oLSM "ColorLinetype")
GMT+8, 2026-10-23 03:28
