ResetProfile 方法 (ActiveX)
将指定配置文件中的值重置为其默认值。 支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持 返回值 (RetVal)无返回值。 言论指定的配置文件必须是当前活动配置文件。若要将配置文件设置为当前活动配置文件,请使用该属性。ActiveProfile 例子VBA: Sub Example_ResetProfile()
' This example resets a profile to the default values.
' NOTE: A dummy profile name is used so that your existing
' profiles are not changed.
Dim strProfileToReset As String
Set preferences = ThisDrawing.Application.preferences
' Specify the profile to delete.
strProfileToReset = "TestProfile"
' Delete the profile
' The call will fail if "TestProfile" does not exist
On Error GoTo Error
preferences.Profiles.ResetProfile strProfileToReset
Exit Sub
Error:
MsgBox "ResetProfile of " & strProfileToReset & " failed. " & Err.Description, , "ResetProfile Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ResetProfile()
;; This example resets a profile to the default values.
;; NOTE: A dummy profile name is used so that your existing
;; profiles are not changed.
;; Specify the profile to delete.
(setq strProfileToReset "TestProfile")
;; Reset the profile
;; The call will fail if "TestProfile" does not exist
(setq err (vl-catch-all-apply 'vla-ResetProfile (list (vla-get-Profiles preferences) strProfileToReset)))
(if (= (type err) 'VL-CATCH-ALL-APPLY-ERROR)
(alert (strcat "ResetProfile of " strProfileToReset " failed. "))
(alert (strcat "We have just reset the profile " strProfileToReset))
GMT+8, 2026-11-3 15:19
