RenameProfile 方法 (ActiveX)
重命名指定的配置文件。 支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持 签名VBA: object.RenameProfile origProfileName, newProfileName
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_RenameProfile()
' This example renames an existing profile.
' You can see the renamed profile under Options/Profiles
' *Note: This example relies on the default profile "<<Unnamed Profile>>".
' If this profile has already been renamed or removed, be sure to change the
' name of the SourceProfile to one that currently exists.
Dim ACADPref As AcadPreferencesProfiles
Dim SourceProfile As String, DestinationProfile As String
' Get the profiles preferences object
Set ACADPref = ThisDrawing.Application.preferences.Profiles
' Rename the default profile
On Error GoTo ERRORTRAP
SourceProfile = "<<Unnamed Profile>>"
DestinationProfile = "NEW_PROFILE_NAME"
ACADPref.RenameProfile SourceProfile, DestinationProfile
MsgBox "We have just renamed the profile " & SourceProfile & " to " & DestinationProfile
Exit Sub
ERRORTRAP:
If Err.Description <> "" Then
MsgBox "The default profile '" & SourceProfile & "' cannot be found, please use a different source profile."
End If
可视化 LISP: (vl-load-com)
(defun c:Example_RenameProfile()
;; This example renames an existing profile.
;; You can see the renamed profile under Options/Profiles
;; *Note: This example relies on the default profile "<<Unnamed Profile>>".
;; If this profile has already been renamed or removed, be sure to change the
;; name of the SourceProfile to one that currently exists.
;; Rename the default profile
(setq sourceProfile "<<Unnamed Profile>>"
destinationProfile "NEW_PROFILE_NAME")
(setq err (vl-catch-all-apply 'vla-RenameProfile (list (vla-get-Profiles preferences) sourceProfile destinationProfile)))
(if (= (type err) 'VL-CATCH-ALL-APPLY-ERROR)
(alert (strcat "The default profile '" SourceProfile "' cannot be found, please use a different source profile."))
(alert (strcat "We have just renamed the profile " SourceProfile " to " DestinationProfile))
GMT+8, 2026-11-2 10:15
