AutoCAD 2024 开发者帮助
PolarPoint 方法 (ActiveX)
2024-5-18 19:07| 发布者: admin| 查看: 909| 评论: 0|原作者: admin|来自: AutoCAD
获取与给定点的指定角度和距离的点。
RetVal = object.PolarPoint(Point, Angle, Distance)
类型: 实用程序
此方法应用到的对象。
点
访问:仅输入
类型:变体(双打的三元素阵列)
指定起点的 3D WCS 坐标。
角度
访问:仅输入
类型:双
以弧度为单位的角度。
距离
访问:仅输入
类型:双
以当前单位表示的距离。
返回值 (RetVal)
类型:变体(双打的三元素阵列)
3D WCS 与给定点的指定角度和距离坐标。
Sub Example_PolarPoint()
    ' This example finds the coordinate of a point that is a given
    ' distance and angle from a base point.
    Dim polarPnt As Variant
    Dim basePnt(0 To 2) As Double
    Dim angle As Double
    Dim distance As Double
    basePnt(0) = 2#: basePnt(1) = 2#: basePnt(2) = 0#
    angle = 0.1744444   ' 45 degrees
    distance = 5
    polarPnt = ThisDrawing.Utility.PolarPoint(basePnt, angle, distance)
    ' Create a line from the base point to the polar point
    Dim lineObj As AcadLine
    Set lineObj = ThisDrawing.ModelSpace.AddLine(basePnt, polarPnt)
    ZoomAll
(defun c:Example_PolarPoint()
    ;; This example finds the coordinate of a point that is a given
    ;; distance and angle from a base point.
    (setq basePnt (vlax-3d-point 2 2 0)
          ang 0.1744444   ;; 45 degrees
          dist 5)
    (setq polarPnt (vla-PolarPoint (vla-get-Utility doc) basePnt ang dist))
    ;; Create a line from the base point to the polar point
    (setq lineObj (vla-AddLine modelSpace basePnt polarPnt))
    (vla-ZoomAll acadObj)
GMT+8, 2026-10-23 10:41
