AutoCAD 2024 开发者帮助
InsertMenuInMenuBar 方法 (ActiveX)
2024-5-18 19:07| 发布者: admin| 查看: 983| 评论: 0|原作者: admin|来自: AutoCAD
将菜单插入到 AutoCAD 菜单栏中。
object.InsertMenuInMenuBar MenuName, Index
类型:弹出菜单
此方法应用到的对象。
菜单名称
访问:仅输入
类型:字符串
要插入到菜单栏中的弹出菜单的名称。
指数
访问:仅输入
类型:变体
菜单栏中用于放置弹出菜单的索引。索引必须是整数或字符串。
如果是整数,则索引必须介于 0 和 N-1 之间,其中 N 是菜单栏中的弹出菜单数。
如果是字符串,则弹出菜单的名称必须包含菜单中显示的任何下划线。
返回值 (RetVal)
无返回值。
菜单紧接在指定的索引位置之前插入。
Sub Example_InsertMenuInMenuBar()
    ' This example creates a new menu called TestMenu and inserts a menu item
    ' into it. The menu is then displayed on the menu bar.
    Dim currMenuGroup As acadMenuGroup
    Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
    ' Create the new menu
    Dim newMenu As AcadPopupMenu
    Set newMenu = currMenuGroup.Menus.Add("TestMenu")
    ' Add a menu item to the new menu
    Dim newMenuItem As AcadPopupMenuItem
    Dim openMacro As String
    ' Assign the macro string the VB equivalent of "ESC ESC _open "
    openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
    Set newMenuItem = newMenu.AddMenuItem(newMenu.count + 1, "Open", openMacro)
    ' Display the menu on the menu bar
    currMenuGroup.Menus.InsertMenuInMenuBar "TestMenu", ""
(defun c:Example_InsertMenuInMenuBar()
    ;; This example creates a new menu called TestMenu and inserts a menu item
    ;; into it. The menu is then displayed on the menu bar.
    (setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
    ;; Create the new menu
    (setq newMenu (vla-Add (vla-get-Menus currMenuGroup) "TestMenu"))
    ;; Add a menu item to the new menu
    ;; Assign the macro string the VB equivalent of "ESC ESC _open "
    (setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
    (setq newMenuItem (vla-AddMenuItem newMenu (1+ (vla-get-Count newMenu)) "Open" openMacro))
    ;; Display the menu on the menu bar
    (vla-InsertMenuInMenuBar (vla-get-Menus currMenuGroup) "TestMenu" "")
    ;; Display the menu bar
    (vla-SetVariable doc "MENUBAR" 1)
GMT+8, 2026-10-22 20:29
