ImportProfile 方法 (ActiveX)
导入由其他用户创建的配置文件。 支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持 签名VBA: object.ImportProfile Profile, RegFile, IncludePathInfo
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_ImportProfile()
' This example imports a profile.
' NOTE: A dummy profile name is used so that your existing
' profiles are not changed.
Dim strProfileToImport As String
Set preferences = ThisDrawing.Application.preferences
' Specify the profile to delete.
strProfileToImport = "TestProfile"
' Delete the profile
' The call will fail if "TestProfile" does not exist
On Error GoTo Error
preferences.Profiles.ImportProfile strProfileToImport, "TESTPROFILE.ARG", True
Exit Sub
Error:
MsgBox "ImportProfile of " & strProfileToImport & " failed. " & Err.Description, , "ImportProfile Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ImportProfile()
;; This example imports a profile.
;; NOTE: A dummy profile name is used so that your existing
;; profiles are not changed.
;; Specify the profile to import.
(setq strProfileToImport "TestProfile")
(vla-ImportProfile (vla-get-Profiles preferences) strProfileToImport (findfile "TESTPROFILE.ARG") :vlax-true)
GMT+8, 2026-9-6 10:58
