AutoCAD 2024 开发者帮助
GetRemoteFile 方法 (ActiveX)
2024-5-18 19:07| 发布者: admin| 查看: 888| 评论: 0|原作者: admin|来自: AutoCAD
下载 URL 指定的文件。
object.GetRemoteFile URL, LocalFile, IgnoreCache
类型: 实用程序
此方法应用到的对象。
网址
访问:仅输入
类型:字符串
要下载的文件的 URL。
本地文件
访问:仅输出
类型:字符串
指定 URL 中的文件。
忽略缓存
访问:仅输入
类型:布尔
  • True:即使文件已在此会话中传输,也可下载。
  • False:如果文件已在此会话中传输,则不下载。
返回值 (RetVal)
无返回值。
如果维护已在当前会话或上一个会话(缓存)中下载的文件列表,则避免重复传输并改为创建本地可用文件的副本可能会更有效。您可以通过将 IgnoreCache 参数设置为 显式强制下载,在这种情况下,缓存将被完全绕过。True
访问安全 URL 时,将发布一个对话框,提示用户输入必要的密码信息。如果用户尚未在浏览器中禁止此活动,则还会显示消息框。
下载文件时,AutoCAD 会创建一个临时文件进行内部处理。不要尝试访问此临时文件。此文件中的信息将在 AutoCAD 任务结束时删除。
Sub Example_GetRemoteFile()
    ' This example will prompt the user for a URL to download and will verify that
    ' a proper URL was entered.  After downloading, the example will attempt to load
    ' the downloaded URL as a drawing.
    ' * Note: Remember to delete the downloaded file from your disk drive when finished.
    Dim Utility As AcadUtility
    Dim URL As String, DestFile As String, FileURL As String
    Set Utility = ThisDrawing.Utility   ' Connect to Utility object
GETURL:
    ' Prompt user for a URL to download.  This should be a URL to an AutoCAD drawing file.
    URL = Utility.GetString(False, vbLf & "Enter the complete URL of the file you wish to download: ")
    URL = Trim(URL)                     ' Get rid of blank spaces
    If URL = "" Then Exit Sub           ' Did user cancel
    ' Determine if user entered a valid URL; if not, prompt again
    If Not (Utility.IsURL(URL)) Then
        MsgBox "The URL you entered is not valid.  Make sure the syntax is a valid URL."
        GoTo GETURL
    End If
    ' Download URL
    Utility.GetRemoteFile URL, DestFile, True
    ' Display downloaded file information
    MsgBox URL & " was downloaded to: " & DestFile
    ' Use IsRemoteFile to determine if this file was downloaded from a URL.
    ' If it was, display the URL it was downloaded from
    ' * Note: Although the results that IsRemoteFile will return are already known
    ' since the file was just downloaded it is important to know how this
    ' method can be used.
    If Utility.IsRemoteFile(DestFile, FileURL) Then
        MsgBox "The file: " & DestFile & " is a downloaded file and was downloaded from: " & FileURL
    Else
        MsgBox "The file: " & DestFile & " is not a downloaded file."
    End If
(defun c:Example_GetRemoteFile()
    ;; This example will prompt the user for a URL to download and will verify that
    ;; a proper URL was entered.  After downloading, the example will provide information
    ;; about the downloaded drawing.
    ;; * Note: Remember to delete the downloaded file from your disk drive when finished.
    (setq Utility (vla-get-Utility doc))   ;; Connect to Utility object
    ;; Prompt user for a URL to download.  This should be a URL to an AutoCAD drawing file.
    (setq URL (vla-GetString Utility :vlax-false "\nEnter the complete URL of the file you wish to download: "))
    (if (/= URL "")
        (progn
	           (if (= (vla-IsURL Utility URL) :vlax-false)
	               (alert "The URL you entered is not valid.  Make sure the syntax is a valid URL.")
	               (progn
		                  ;; Download URL
		                  (vla-GetRemoteFile Utility URL 'DestFile :vlax-true)
		                  ;; Display downloaded file information
		                  (alert (strcat URL " was downloaded to: " DestFile "\n"))
		                  ;; Use IsRemoteFile to determine if this file was downloaded from a URL.
	              	    ;; If it was, display the URL it was downloaded from
		                  ;; * Note: Although the results that IsRemoteFile will return are already known
		                  ;; since the file was just downloaded it is important to know how this
		                  ;; method can be used.
		                  (if (= (vla-IsRemoteFile Utility DestFile URL) :vlax-true)
		                      (alert (strcat "The file: " DestFile " is a downloaded file and was downloaded from: " URL))
		                      (alert (strcat "The file: " DestFile " is not a downloaded file."))
GMT+8, 2026-10-22 12:45
