AutoCAD 2024 开发者帮助
GetInput 方法 (ActiveX)
2024-5-18 19:07| 发布者: admin| 查看: 835| 评论: 0|原作者: admin|来自: AutoCAD
将用户的输入字符串转换为关键字索引。
RetVal = object.GetInput()
类型: 实用程序
此方法应用到的对象。
返回值 (RetVal)
类型:字符串
指定输入关键字的索引。
此方法检索 AutoCAD 用户在调用其中一个用户输入函数( 方法)期间输入的关键字。Get*
关键字的最大长度为 511 个字符(第 512 个字符保留给该字符)。NULL
对的调用是没有意义的,除非它紧随对用户输入函数之一的调用之后,否则将失败。即便如此,只有当用户输入函数返回错误描述“用户输入是关键字”时,调用才会成功。GetInput
无需在调用方法后调用。GetInputGetKeyword
应用程序识别的关键字由对方法的先前调用指定。关键字的解释完全取决于应用程序。关键字不应与AutoCAD命令的名称重复。InitializeUserInput
用户可以缩写关键字,但始终返回在调用中使用原始大写定义的完整关键字,因此应用程序只需对其定义的每个关键字进行一个字符串比较。GetInputInitializeUserInput
Sub Example_GetInput()
    ' This example prompts for user input of a point. By using the
    ' InitializeUserInput method to define a keyword list, the example can also
    ' return keywords entered by the user.
    On Error Resume Next
    ' Define the valid keywords
    Dim keywordList As String
    keywordList = "Line Circle"
    ' Call InitializeUserInput to set up the keywords
    ThisDrawing.Utility.InitializeUserInput 128, keywordList
    ' Get the user input
    Dim returnPnt As Variant
    returnPnt = ThisDrawing.Utility.GetPoint(, vbLf & "Enter a point [Line/Circle]: ")
    If Err Then
         If StrComp(Err.Description, "User input is a keyword", 1) = 0 Then
         ' One of the keywords was entered
             Dim inputString As String
             Err.Clear
             inputString = ThisDrawing.Utility.GetInput
             MsgBox "You entered the keyword: " & inputString
         Else
             MsgBox "Error selecting the point: " & Err.Description
             Err.Clear
         End If
    Else
        ' Display point coordinates
        MsgBox "The WCS of the point is: " & returnPnt(0) & ", " & returnPnt(1) & ", " & returnPnt(2), , "GetInput Example"
    End If
(defun c:Example_GetInput()
    ;; This example prompts for user input of a point. By using the
    ;; InitializeUserInput method to define a keyword list, the example can also
    ;; return keywords entered by the user.
    ;; Define the valid keywords
    (setq keywordList "Line Circle")
    ;; Call InitializeUserInput to set up the keywords
    (vla-InitializeUserInput (vla-get-Utility doc) 128 keywordList)
    ;; Get the user input
    (setq returnPntOrErr (vl-catch-all-apply 'vla-GetPoint (list (vla-get-Utility doc) nil "Enter a point [Line/Circle]: ")))
    (if (= (type returnPntOrErr)'VL-CATCH-ALL-APPLY-ERROR)
        (progn
            (if (= (vl-catch-all-error-message returnPntOrErr) "Automation Error. User input is a keyword")
	               (progn
                    (setq inputString (vla-GetInput (vla-get-Utility doc)))
                    (alert (strcat "You entered the keyword: " inputString))
                (alert "User pressed ESC or unknown input was provided.")
        ;; Display point coordinates
        (progn
	           (setq returnPnt (vlax-safearray->list (vlax-variant-value returnPntOrErr)))
            (alert (strcat "The WCS of the point is: " (rtos (nth 0 returnPnt) 2) ", " (rtos (nth 1 returnPnt) 2) ", " (rtos (nth 2 returnPnt) 2)))
GMT+8, 2026-10-23 02:21
