GetGridVisibility 方法 (ActiveX)
返回指定网格线型和行类型的网格可见性值。 支持的平台:仅限 Windows 签名VBA: RetVal = object.GetGridVisibility(gridLineType, rowType)
返回值 (RetVal)类型:布尔
言论没有其他评论。 例子VBA: Sub Example_GetGridVisibility()
' the style name and other attributes.
Dim dictObj As AcadDictionary
' Get the current TableStyle object
Dim tableStyle As AcadTableStyle
Set tableStyle = dictObj.Item(ThisDrawing.GetVariable("CTABLESTYLE"))
Dim colGridCurrent As AcadAcCmColor, lwGridCurrent As ACAD_LWEIGHT, visGridCurrent As Boolean
Set colGridCurrent = tableStyle.GetGridColor(acHorzBottom, acTitleRow)
lwGridCurrent = tableStyle.GetGridLineWeight(acHorzBottom, acTitleRow)
visGridCurrent = tableStyle.GetGridVisibility(acHorzTop, acTitleRow)
MsgBox "Grid settings " & vbLf & _
"nColor (Bottom) = " & colGridCurrent.ColorIndex & vbLf & _
"nLineweight (Bottom) = " & lwGridCurrent & vbLf & _
"Visibility (Top) = " & visGridCurrent
Dim col As AcadAcCmColor
Set col = tableStyle.GetGridColor(acHorzBottom, acTitleRow)
col.SetRGB 0, 0, 255
tableStyle.SetGridColor acHorzBottom, acTitleRow, col
tableStyle.SetGridLineWeight acHorzBottom, acTitleRow, acLnWt025
If visGridCurrent = False Then
tableStyle.SetGridVisibility acHorzTop, acTitleRow, True
Else
tableStyle.SetGridVisibility acHorzTop, acTitleRow, False
End If
Dim colGridNew As AcadAcCmColor, lwGridNew As ACAD_LWEIGHT, visGridNew As Boolean
Set colGridNew = tableStyle.GetGridColor(acHorzBottom, acTitleRow)
lwGridNew = tableStyle.GetGridLineWeight(acHorzBottom, acTitleRow)
visGridNew = tableStyle.GetGridVisibility(acHorzTop, acTitleRow)
"nColor (Bottom) = " & colGridNew.ColorIndex & vbLf & _
"nLineweight (Bottom) = " & lwGridNew & vbLf & _
"Visibility (Top) = " & visGridNew
tableStyle.SetGridColor acHorzBottom, acTitleRow, colGridCurrent
tableStyle.SetGridLineWeight acHorzBottom, acTitleRow, lwGridCurrent
tableStyle.SetGridVisibility acHorzTop, acTitleRow, visGridCurrent
MsgBox "Reset the table style back to its original values."
可视化 LISP: (vl-load-com)
(defun c:Example_GetGridVisibility()
;; the style name and other attributes.
doc (vla-get-ActiveDocument acadObj))
(setq dictionaries (vla-get-Dictionaries doc)
dictObj (vla-Item dictionaries "acad_tablestyle"))
;; Get the current TableStyle object
(setq tableStyle (vla-Item dictObj (vla-GetVariable doc "CTABLESTYLE")))
(setq colGridCurrent (vla-GetGridColor tableStyle acHorzBottom acTitleRow)
lwGridCurrent (vla-GetGridLineWeight tableStyle acHorzBottom acTitleRow)
visGridCurrent (vla-GetGridVisibility tableStyle acHorzTop acTitleRow))
(alert (strcat "Grid settings"
"\nColor (Bottom) = " (itoa (vla-get-ColorIndex colGridCurrent))
"\nLineweight (Bottom) = " (itoa lwGridCurrent)
"\nVisibility (Top)= " (if (= visGridCurrent :vlax-true) "True" "False")))
(setq col (vla-GetGridColor tableStyle acHorzBottom acTitleRow))
(vla-SetRGB col 0 0 255)
(vla-SetGridColor tableStyle acHorzBottom acTitleRow col)
(vla-SetGridLineWeight tableStyle acHorzBottom acTitleRow acLnWt025)
(vla-SetGridVisibility tableStyle acHorzTop acTitleRow (if (= visGridCurrent :vlax-true) :vlax-false :vlax-true))
(setq colGridNew (vla-GetGridColor tableStyle acHorzBottom acTitleRow)
lwGridNew (vla-GetGridLineWeight tableStyle acHorzBottom acTitleRow)
visGridNew (vla-GetGridVisibility tableStyle acHorzTop acTitleRow))
"\nColor (Bottom) = " (itoa (vla-get-ColorIndex colGridNew))
"\nLineweight (Bottom) = " (itoa lwGridNew)
"\nVisibility (Top)= " (if (= visGridNew :vlax-true) "True" "False")))
(vla-SetGridColor tableStyle acHorzBottom acTitleRow colGridCurrent)
(vla-SetGridLineWeight tableStyle acHorzBottom acTitleRow lwGridCurrent)
(vla-SetGridVisibility tableStyle acHorzBottom acTitleRow visGridCurrent)
(alert "Reset the table style back to its original values.")
GMT+8, 2026-10-22 07:08
