AutoCAD 2024 开发者帮助
GetFitPoint 方法 (ActiveX)
2024-5-18 19:07| 发布者: admin| 查看: 1077| 评论: 0|原作者: admin|来自: AutoCAD
获取样条曲线在给定索引处的拟合点。
RetVal = object.GetFitPoint(Index)
类型:样条曲线
此方法应用到的对象。
指数
访问:仅输入
类型:长
拟合点列表中要查询拟合点的位置。索引必须是以 0 开头的正整数。
返回值 (RetVal)
类型:变体(双打的三元素阵列)
拟合点在给定索引位置的 3D WCS 坐标。
Sub Example_GetFitPoint()
    ' This example creates a spline object in model space.
    ' It then finds the coordinates of the fit points.
    ' Create the spline
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double
    Dim endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
    fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
    fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ZoomAll
    ' Display the coordinates of the fit points
    Dim fitPoint As Variant
    Dim index As Integer
    For index = 0 To splineObj.NumberOfFitPoints - 1
        fitPoint = splineObj.GetFitPoint(index)
        MsgBox "Fit point " & index + 1 & " is at " & fitPoint(0) & ", " & fitPoint(1) & ", " & fitPoint(2), , "GetFitPoint Example"
    Next
(defun c:Example_GetFitPoint()
    ;; This example creates a spline object in model space.
    ;; It then finds the coordinates of the fit points.
    ;; Create the spline
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(1 1 0
                                     5 5 0
                                     10 0 0
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    ;; Display the coordinates of the fit points
    (setq index 0)
    (while (>= (1- (vla-get-NumberOfFitPoints splineObj)) 0)
        (setq fitPoint (vlax-safearray->list (vlax-variant-value (vla-GetFitPoint splineObj index))))
        (alert (strcat "Fit point " (itoa (1+ index)) " is at " (rtos (nth 0 fitPoint) 2) ", " (rtos (nth 1 fitPoint) 2) ", " (rtos (nth 2 fitPoint) 2)))
        (setq index (1+ index))
GMT+8, 2026-10-31 05:06
