AutoCAD 2024 开发者帮助
GetControlPoint 方法 (ActiveX)
2024-5-18 19:07| 发布者: admin| 查看: 824| 评论: 0|原作者: admin|来自: AutoCAD
获取控制点在给定索引处的坐标。
RetVal = object.GetControlPoint(Index)
类型:样条曲线
此方法应用到的对象。
指数
访问:仅输入
类型:整数
要查询的控制点的索引位置。索引必须是以零开头的正整数。
返回值 (RetVal)
类型:变体(双打的三元素阵列)
控制点在给定索引位置的 3D WCS 坐标。
控制点通过向样条曲线的一部分添加权重来微调样条定义。
可以使用该属性查询样条曲线中控制点的总数。您可以使用该方法为控制点设置新的坐标位置。您可以使用该方法为控制点设置新权重。NumberOfControlPointsSetControlPointSetWeight
Sub Example_GetControlPoint()
    ' This example creates a spline object in model space.
    ' It then finds the coordinates of the first control point
    ' and changes that value.
    ' Create the spline
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double
    Dim endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
    fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
    fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ZoomAll
    ' Display the coordinates of the first control point
    Dim controlPoint As Variant
    controlPoint = splineObj.GetControlPoint(0)
    MsgBox "Control point 1 is at " & controlPoint(0) & ", " & controlPoint(1) & ", " & controlPoint(2), , "GetControlPoint Example"
    ' Change the coordinate of the first fit point
    controlPoint(0) = 0: controlPoint(1) = 3: controlPoint(2) = 0
    splineObj.SetControlPoint 0, controlPoint
    splineObj.Update
    MsgBox "Control point 1 is now at " & controlPoint(0) & ", " & controlPoint(1) & ", " & controlPoint(2), , "GetControlPoint Example"
(defun c:Example_GetControlPoint()
    ;; This example creates a spline object in model space.
    ;; It then finds the coordinates of the first control point
    ;; and changes that value.
    ;; Create the spline
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(1 1 0
                                     5 5 0
                                     10 0 0
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    ;; Display the coordinates of the first control point
    (setq controlPoint (vlax-safearray->list (vlax-variant-value (vla-GetControlPoint splineObj 0))))
    (alert (strcat "Control point 1 is at " (rtos (nth 0 controlPoint) 2) ", " (rtos (nth 1 controlPoint) 2) ", " (rtos (nth 2 controlPoint) 2)))
    ;; Change the coordinate of the first fit point
    (setq controlPoint (vlax-3d-point 0 3 0))
    (vla-SetControlPoint splineObj 0 controlPoint)
    (vla-Update splineObj)
    (alert (strcat "Control point 1 is now at " (rtos (nth 0 controlPoint) 2) ", " (rtos (nth 1 controlPoint) 2) ", " (rtos (nth 2 controlPoint) 2)))
GMT+8, 2026-9-6 08:42
