AutoCAD 2024 开发者帮助
GetCellStyle 方法 (ActiveX)
2024-5-18 19:07| 发布者: admin| 查看: 799| 评论: 0|原作者: admin|来自: AutoCAD
获取单元格样式。
RetVal = object.GetCellStyle(nRow, nCol)
类型: 表格
此方法应用到的对象。
nRow(n行)
访问:仅输入
类型:长
要设置的单元格的行号。
nCol (英语:nCol)
访问:仅输入
类型:长
要设置的单元格的列号。
返回值 (RetVal)
类型:字符串
单元格样式。
Sub Example_CellManipulation()
    ' This example adds a table in model space and sets and gets a column name
    Dim MyModelSpace As AcadModelSpace
    Set MyModelSpace = ThisDrawing.modelSpace
    Dim pt(2) As Double
    Dim MyTable As AcadTable
    Dim cName As String
    Set MyTable = MyModelSpace.AddTable(pt, 5, 5, 10, 30)
    Call MyTable.SetCellDataType(2, 2, acLong, acUnitDistance)
    Call MyTable.SetCellFormat(1, 3, "testFormat")
    Call MyTable.SetCellState(4, 3, acCellStateContentLocked)
    Call MyTable.SetCellValue(1, 4, 5)
    MsgBox MyTable.GetCellValue(1, 4) & " is the test cell's value "
    ZoomExtents
(defun c:Example_CellManipulation()
    ;; This example adds a table in model space and sets and gets a column name
    (setq pt (vlax-3d-point 0 0 0))
    (setq MyTable (vla-AddTable modelSpace pt 5 5 10 30))
    (vla-SetCellDataType MyTable 2 2 acLong acUnitDistance)
    (vla-SetCellFormat MyTable 1 3 "testFormat")
    (vla-SetCellState MyTable 4 3 acCellStateContentLocked)
    (vla-SetCellValue MyTable 1 4 5)
    (alert (strcat (itoa (vlax-variant-value (vla-GetCellValue MyTable 1 4))) " is the test cell's value."))
    (vla-ZoomExtents acadObj)
GMT+8, 2026-11-2 18:44
