AutoCAD 2024 开发者帮助
ExportProfile 方法 (ActiveX)
2024-5-18 19:07| 发布者: admin| 查看: 835| 评论: 0|原作者: admin|来自: AutoCAD
导出活动配置文件,以便与其他用户共享。
支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持
object.ExportProfile Profile, RegFile
类型:PreferencesProfiles
此方法应用到的对象。
轮廓
访问:仅输入
类型:字符串
要导出的配置文件的名称。
注册文件
访问:仅输入
类型:字符串
配置文件将导出到的文件的名称。文件的扩展名应为 .arg。
返回值 (RetVal)
无返回值。
Sub Example_ExportProfile()
    ' This example exports the active profile to a new name.
    Dim currActiveProfile As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current ActiveProfile value
    currActiveProfile = preferences.Profiles.ActiveProfile
    MsgBox "The current ActiveProfile is: " & preferences.Profiles.ActiveProfile, , "ExportProfile Example"
    ' Export the active profile
    preferences.Profiles.ExportProfile currActiveProfile, "TestProfile.arg"
    MsgBox "The ActiveProfile has been exported to: TestProfile.arg", , "ExportProfile Example"
(defun c:Example_ExportProfile()
    ;; This example exports the active profile to a new name.
    ;; Retrieve the current ActiveProfile value
    (setq currActiveProfile (vla-get-ActiveProfile (vla-get-Profiles preferences)))
    (alert (strcat "The current ActiveProfile is: " currActiveProfile))
    ;; Export the active profile
    (vla-ExportProfile (vla-get-Profiles preferences) currActiveProfile "c:\\Temp\\TestProfile.arg")
    (alert "The ActiveProfile has been exported to: TestProfile.arg")
GMT+8, 2026-10-23 08:45
