AutoCAD 2024 开发者帮助
Display 方法 (ActiveX)
2024-5-18 19:07| 发布者: admin| 查看: 712| 评论: 0|原作者: admin|来自: AutoCAD
打开或关闭 PViewport 对象的显示控件。
object.Display Status
类型: PViewport
此方法应用到的对象。
地位
访问:仅输入
类型:布尔
  • True:视口显示已打开。
  • False:视口显示已关闭。
返回值 (RetVal)
无返回值。
显示控件必须处于打开状态,然后才能使用该属性激活模型空间编辑功能。MSpace
使用该属性可确定是否已使用此方法打开纸张空间视口显示。ViewportOn
Sub Example_DisplayMethod()
    ' This example creates a paper space viewport and makes it active.
    Dim newPViewport As AcadPViewport
    Dim height As Double
    Dim width As Double
    height = 30#
    width = 40#
    centerPoint(0) = 30#: centerPoint(1) = 30#: centerPoint(2) = 0#
    ' Create a paper space Viewport object
    ThisDrawing.ActiveSpace = acPaperSpace
    Set newPViewport = ThisDrawing.PaperSpace.AddPViewport(centerPoint, width, height)
    ZoomAll
    newPViewport.Display True
    ' Before making a pViewport active,
    ' the mspace property needs to be True
    ThisDrawing.mspace = True
    ThisDrawing.ActivePViewport = newPViewport
(defun c:Example_DisplayMethod()
    ;; This example creates a paper space viewport and makes it active.
    (setq centerPoint (vlax-3d-point 30 30 0)
          height 30
          width 40)
    ;; Create a paper space Viewport object
    (vla-put-ActiveSpace doc acPaperSpace)
    (setq newPViewport (vla-AddPViewport (vla-get-PaperSpace doc) centerPoint width height))
    (vla-ZoomAll acadObj)
    (vla-Display newPViewport :vlax-true)
    ;; Before making a pViewport active,
    ;; the mspace property needs to be True
    (vla-put-MSpace doc :vlax-true)
    (vla-put-ActivePViewport doc newPViewport)
GMT+8, 2026-10-26 13:22
